Real Big Big block question..
Old Aug 10, 2003 | 04:11 PM
just2Bfast's Avatar
Question Real Big Big block question..
I'm planing to put a bigblock chevy in my 84 camaro I want to wait for the 572 create from chevy, can I do this. mony is not the problem, how hard can it be?
Old Aug 10, 2003 | 04:53 PM
stevem's Avatar
anything is possible i just takes money
cant wait to see pics of it
Old Aug 10, 2003 | 05:21 PM
TheGreatJ's Avatar
Exhaust is a huge issue. You'll probably have to have headers custom made for the car, and they will most likely have to come through the wheelwell because there won't be much room between the block and subframe.
Hood clearance may be a problem...you might have to run a cowl hood in order to fit an aircleaner in.
Get an aftermarket radiator and dual electric fans. I'd be surprised if the stock cooling system could keep up with a big block's heat production.
Otherwise, it shouldn't be that difficult. You may have to do a little fabbing for motor and tranny mounts, but you won't have to cut any chunks out of the firewall or anything. The car is gonna be VERY frontheavy when you're done...better plan on a big brake upgrade soon after the swap.
Old Aug 10, 2003 | 06:18 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Im prettu sure you have to put new stiffer front springs in too. Because of all the extra weight as previously stated.
Old Aug 10, 2003 | 06:26 PM
RobsWS6's Avatar
I think Hooker made a kit in the early-mid '80's. Maybe try to see if they still make it.
Old Aug 10, 2003 | 07:04 PM
Geezer powered's Avatar
it has been done just make sure you don't have to change the plugs until 50,000. there is not much room left in there.
Old Aug 10, 2003 | 08:50 PM
doug791's Avatar
lol im loving it have to pull the motor to change the plugs.
Old Aug 10, 2003 | 11:58 PM
you got it doug
Old Aug 12, 2003 | 01:03 PM
88 427 Camaro's Avatar
Actually changing 7 of 8 plugs with the BBC is easier than with the sbc. The #7 plug is the tough one as I can only get to it from underneath the car and that's with the hooker super comp headers.
Miles
Old Aug 12, 2003 | 10:20 PM
m0nk's Avatar
check out this http://www.difftechnics.com/original.html
then talk to 88 427 Camaro
im sure that will solve about 99% of your questions
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
