RE: Thermostat
Old Aug 14, 2004 | 06:15 PM
  #16
Marc 85Z28's Avatar
Re: Thermostat
Originally Posted by IROC-T
you DO need the stat or at least the flow restrictor rings that are used in racing (that is why they use them)so you do non't get the hot spots. Without them the temp can run as much as hundred degrees differance from front to back of the block. But this is just BS and all of these people that are saying this are just idiots right?
I am aware of the restrictors used in racing. Having some first hand experience with a late model dirt track car, I've seen them. However, they are used in a RACE engine that is WOT 90% of the time, running constant high rpm at high HP levels. And this relates to street driving how?
BTW - Those hot spots you refer to are created from LACK of coolant flow, or lack of system pressure. NOT excessive flow...
Too lazy to pull your thermo out and find out real world results yourself? Go to a drag strip sometime and locate a few guys with expensive engines in quick cars that occassionally run on the street. You won't find a thermostat in their engine, or any restrictors. Why would they gamble their expensive engine over a cheap part?
What people are saying all of this? Next time you comment on an issue, come to the debate with first-hand experience, and not hearsay
Old Aug 15, 2004 | 12:37 AM
  #17
IROC-T's Avatar
Re: Thermostat
Again Key word here is : "occassionaly"
People saying this is in referance to using a thermostat.
Jeff1904
Jun 5, 2016 05:00 PM
4586
Aug 24, 2015 11:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
VetteThreat
Jun 18, 2002 01:53 PM
