questions about my 92 firebird
Old Nov 5, 2007 | 04:05 PM
druhill's Avatar
im having a hard time getting it to turn over. the starter has no power when the key is on. the fuel pump has no power either. i put a new ignition switch in and no deal. so im just wondering if you know what u think i should do????? the starter can be jumped from battery but wont fire up also.
Old Nov 5, 2007 | 05:14 PM
mako350Z28's Avatar
May be a bit far fetched, but the key itself may be the problem. If the resistor in the key is the problem you will get the same results. (or lack of)
Old Nov 6, 2007 | 06:27 PM
red94chicken's Avatar
did you try cleaning the battery terminals? or possibly replacing the cables? its not the chip in the key.. it wouldn't turn over at all.
Old Nov 9, 2007 | 10:21 PM
TA'95's Avatar
I have a 92 Firebird Formula and i believe i had the same problem as you do. But my key would turn over and not crank so it ended up being my cables were too loose on the battery. So i would suggest checking for excessive corrosion on the terminals and/or tightening the battery cables up. I hope i helped
92 Firebird Formula WS6, 305 TPI, Hypertechchip, Slp runners, Dual Flowmasters, B&M shifter, Very good condition, 4,000 cash. Bham, AL
Airplanedoc
Feb 1, 2015 07:14 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 13, 2015 09:52 PM
cmdeshon
Dec 27, 2014 10:06 AM
Injuneer
Dec 15, 2014 09:36 AM
