problem with bbk underdrive pulleys
Old Apr 13, 2003 | 07:56 PM
irocz8957's Avatar
Angry problem with bbk underdrive pulleys
i was putting my book underdrive pulleys on today and i got the one on the crank fine and the one on the water pump was fine also but i went to put the one on the alternator and the bolt the hold the pulley wasn't long enough! now it's not the factory alternator so i was wondering if that might have something to do with it? has anybody ever had this problem before?
thanks to all who reply!!!!
Old Apr 13, 2003 | 08:40 PM
TheGreatJ's Avatar
The factory alternator pulley has a spacer behind it, the BBK pulley may not need it. Also check to make sure you're putting it on the right way.
Having a replacement alternator shouldn't make a difference.....I'd be very surprised to find a 3rd gen that still had the original.
Old Apr 15, 2003 | 07:42 AM
irocz8957's Avatar
ttt
Old Apr 15, 2003 | 08:16 AM
Black6SpdTA's Avatar
did you try the spacer behind alt like TheGreatJ said? that sounds like the only reasonable answer.
Old Apr 15, 2003 | 10:32 AM
irocz8957's Avatar
yeah i tried taking the spacer off but there is both a nut and a washer i can fit the nut just barely but the washer wont go on, and i think thats a locking washer so i need that on there!!
Rde Bandit
Mar 21, 2015 10:17 PM
alphaauto
Jan 23, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:34 PM
94z28jbw
Sep 8, 2002 03:22 PM
