Power windows sooo slow
Old Oct 1, 2007 | 10:41 PM
LtsRace's Avatar
Is this just the way these are? Or may they be on their last days?
Is there a write up on changing them out like the one I used for my 96-Z?
Just wondering, any help would be appreciated.
Old Oct 2, 2007 | 01:25 PM
imadude1134's Avatar
im not sure how much different it is on the 4th gens, but there is a great write-up of how do do one on a 3rd gen on www.thirdgen.org
With it going slow, i can say that the motor is on its last leg...
Good luck
Old Oct 4, 2007 | 08:13 AM
LtsRace's Avatar
Cool, thanx!
Old Oct 4, 2007 | 09:51 AM
Castro's Avatar
Smile
FYI from my experience if your motor is working then it maybe time for you to open up the door and clean the rails big time. Completely relube everything once your done and you should see a 15% increase in the speed. I have done this twice. Also if you decided your motor just needs to be replaced stick with Delco and avoid the cheaper stuff. Also learned that the hard way
Old Oct 8, 2007 | 05:53 PM
LtsRace's Avatar
Thanks, will do that. And as for motors, I always stick with Delco.
Old Oct 9, 2007 | 04:04 PM
mpilarZ281992's Avatar
Good luck on the window motors. I have replaced both sides 3-4 times, both with aftermarket and Delco. Now I just stick with (may I dare say) an autozone brand for its lifetime warranty. I also drilled into the inner frame for quick removal and installation of the motor since I figured this will be a routine practice.
Old Oct 11, 2007 | 09:00 PM
Damon's Avatar
As the motor assy. wears out they just run slower and slower. Then you replace it and be happy for a few years.
Old Oct 12, 2007 | 06:35 PM
1987IROC350's Avatar
Mine are super slow. I always loved my 1980 Vette. It would go down in about 1 second. And up in 2 flat. I gotta get my IROC like that.
Keenan
Jan 19, 2023 12:24 PM
Heathen1
Jan 2, 2016 04:27 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
