Power window gets stuck
Old Mar 15, 2004 | 06:45 PM
splinter_cell's Avatar
I just installed them too Its my drivers side door. I didnt touch anything inside the door shell. Only thing I did was spray some white lithium grease. I swaped the whole door over. It was working fine earlier but then all of a sudden it gets stuck about 1/2 way and if I keep pressing the switch it makes a terrible noise. It also makes that noise one it goes all the way up. Any suggestions? Please help the Fresno sun is hot!!!
Old Mar 15, 2004 | 07:21 PM
justens95z's Avatar
You might look in LT1 tech. There was a guy over there with an idea for the window motors.
Old Mar 15, 2004 | 08:01 PM
kevin 2.8's Avatar
take off the door panel and see if the runchannel is binding up,
if its really cold out it may make the window harder to move.
try using dish soap and water on the rubber peices on the inside of the door and heavy grease on all the moving parts.
im not sure but i think all the components inside the door are held in by rivets except the glass?
you may want to try adjusting the parts that move a little to see if you get results that way.
it may just be the motor getting weak but this may fix it completly.
Old Mar 15, 2004 | 08:13 PM
Ok, the door panels are off. Does the run channel run vertically? Its weird because it will go down fine and then stop and make this weird noise. Like something is not catching. It also makes the same noise once its fully up and I keep pressing the switch.
Also I was looking at how it goes down and up and the window is pushing the triangle seal. Maybe the window got out of alignment.
Old Mar 15, 2004 | 09:04 PM
TheGreatJ's Avatar
Sounds like the window regulator is stripped out. If you got the door from a junkyard take the car and show them the problem....pitch a fit if they won't give you a window regulator. Yell about how you paid for a good door, not a door with busted up internals.
Old Mar 15, 2004 | 09:06 PM
damnit! how hard is it to replace that regulator? I bet it will be a pain in the ***
Old Mar 15, 2004 | 09:32 PM
TheGreatJ's Avatar
I hope you like drilling out rivets.
Old Mar 15, 2004 | 10:06 PM
kevin 2.8's Avatar
sounds like the rear window on my lincoln.
it just kind of pulses and i have to pull the window up by hand.
the gears that the motor is connected to are chewed up and have to be replaced.
it sucks that all domestic cars use rivets. you just have to drill them out. and there isnt much room to work with inside the camaro door.
Old Mar 18, 2004 | 04:13 PM
wtf!
You guys think its the regulator? It was working fine before. No signs of wear or anything. Then it decides to take a $hit on me I know it probably is but I called a shop up to see how much it would be to fix it and i got quoted at 300!
Old Mar 18, 2004 | 04:25 PM
kevin 2.8's Avatar
is there a wrecker around where you can try a regulator swap?
Old Mar 18, 2004 | 04:28 PM
yeah theres a couple junkyard around me. Im not paying no damn 300 to replace them so I will probably do it my self.
anybody have any experiences?
Old Mar 18, 2004 | 08:45 PM
Ville H. Valo's Avatar
My girlfriend has a 90 Firebird, i just replaced the motor, spring and put the window back on the track. I can tell you what you need, just email me.
-Ville
Old Mar 19, 2004 | 12:41 PM
-Ville
Ok cool.
Keenan
Jan 19, 2023 12:24 PM
Heathen1
Jan 2, 2016 04:27 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
