Posi from 83 rear to 87 rear?
Old Jan 1, 2004 | 01:09 PM
SouthernThunder's Avatar
My car currently has a drum brake open dif 3.42 code 4HL. I have a disk brake posi 3.23 rear from an 83 camaro (4PZ code). I was wondering if it is possible to swap the brakes and diff over to my current rearend (keeping 3.42 ring gear) so I can keep the same lower gear ratio but have posi and disk brakes? I'm not going to run into an axle spline issue am I?
Old Jan 1, 2004 | 05:13 PM
'92 RS Hybrid-Z28's Avatar
As long as they're both 10-bolts you shouldnt have a problem.
Old Jan 1, 2004 | 06:20 PM
Black6SpdTA's Avatar
Re: Posi from 83 rear to 87 rear?
That wasn't until 1989.
3.23+ is 3 series so you're good there.
Brakes--You'll need to do some cutting/grinding of the axle flanges but nothing too difficult.
-Corey
Old Jan 3, 2004 | 09:57 AM
aklim's Avatar
I thought it was 87 and up that they changed over? Not entirely sure but I don't think it was in 89.
Old Jan 4, 2004 | 01:06 PM
Axle splines was definitely in '89 going from 26 to 28.
'87+ was hydraulic roller, maybe that's what you're thinking of?
Old Jan 4, 2004 | 06:35 PM
91 GTA Ramair2's Avatar
Talking go for it man
Ya they should inter change fine but as already stated you may have a bit of grinding to do with the drum to disc swap......
Good luck .......
Old Jan 4, 2004 | 06:46 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Or being rear end related, in '87 I believe the 9 bolt was introduced to the F cars as the performance rear.
1000th post
Old Jan 4, 2004 | 07:37 PM
yea yea that was the general Idea there guy........
good job on the 1000th post ........congat's......
I haven't even really been here a whole minth and i'm well over a 100 posts...... i'll be there soon....
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
CARiD
Feb 9, 2015 09:35 AM
ddr698
Jan 9, 2015 10:05 AM
