LED Lights vs. Bulbs for instrument Panel
Old Dec 21, 2003 | 05:36 PM
camarosource's Avatar
I was wondering if anyone here with a 1990-1992 Camaro has tried installing the LED lights rather than the regular bulbs in your STOCK instrument panel?
I believe it would look similar to http://images.cardomain.com/member_i...983_7_full.jpg (yes, 4th gen, not a 3rd)
These LED's are definately NOT CHEAP and think it would be better to hear first hand who has already done this.
Anyone here have pictures of the end results of the LED's in a STOCK instrument panel?
Old Dec 21, 2003 | 07:59 PM
Dave89IROC's Avatar
do a search over on http://www.thirdgen.org/ , I seem to remember several guys have done it and posted pics
Old Dec 21, 2003 | 09:47 PM
Pro
Guest
Posts: n/a
Yes I will be doing this conversion soon (already did in my truck).
The only problem with going to LEDs (or any other bulb for that matter) is that the cluster overlay is yellow. Put blue lights behind that and you will get a pretty little green (this is discussed at thirdgen.org).
I still havnt figured it out... but for some reason, GM was yellow-happy in the early 90s. All the other 3rd gens were left white/clear.
Old Dec 21, 2003 | 09:53 PM
Where is the yellow? Is it the overlay itself? or a removable yellow stripe inside the instrument panel?
Old Dec 21, 2003 | 10:02 PM
Pro
Guest
Posts: n/a
Not sure yet.
But in the other messages at thirdgen.org they mention some store, where they sell new overlays... so im assuming the yellow is actually built into the overlay.
Old Dec 21, 2003 | 10:05 PM
Not sure yet.
I would rather have a complete Reverse EL glo guage but they don't make them for my Camaro (1992 Camaro Z28 with 240km/140mph guages.) :-(
Old Dec 21, 2003 | 10:31 PM
Pro
Guest
Posts: n/a
What do those guages look like?
Im in the same 140mph guage boat as you...
Old Dec 21, 2003 | 10:42 PM
Pro
Guest
Posts: n/a
Heres a couple of posts on the subject:
http://www.thirdgen.org/techbb2/show...hreadid=215320
http://www.thirdgen.org/techbb2/show...hreadid=215510
Somewhere in there on one of the posts... you can download the "designs" off his webpage. How would this work? Do you just print it off on some sort of special paper? hah
Old Dec 21, 2003 | 10:43 PM
Here is an example of the ones for a Pontiac Firebird. Personally, I would kill for this look for the 1992 Camaro Z28 (240km/140mph)!
http://www.procarparts.com/store-det...%2D20XX%2DRVGX
Old Dec 21, 2003 | 10:53 PM
Post #1. I don't see anything other than a topic regarding shaved door handles.
Post #2: Of course I know of the 2nd post, notice the poster? ;-)
Old Dec 21, 2003 | 11:05 PM
Pro
Guest
Posts: n/a
Maybe it was this one:
http://www.thirdgen.org/techbb2/show...hreadid=213503
My POS computer isnt linking to sites correctly. Plus I have people IMing me like CRAZY RIGHT NOW. (10+ people).
So what about the response of MrDude_1? What are you supposed to do with those designs?
Old Dec 22, 2003 | 08:37 AM
Hawk95's Avatar
Re: LED Lights vs. Bulbs for instrument Panel
That pic is of a stock instrument cluster from a 25th anniv TA. If you have a 4th gen you can just buy that and replace your stock one.
Old Dec 22, 2003 | 03:15 PM
Pro
Guest
Posts: n/a
Hey camarosource, I decided Im going to go ahead and go out on my own (scan my own stuff).
I have access to a ton of special scanners and printers, so Im sure I can get it all to work.
Main reason is because I cant find the 140mph (or 145, whatever it is) designs.
You can clearly see the difference in the two:
ftp://68.1.231.79/New%20Folder/140.jpeg
ftp://68.1.231.79/New%20Folder/110.jpeg
But I guess I can just put all the overlays on transparency?
Old Dec 22, 2003 | 03:21 PM
What exactly are you planning on doing? :-)
I still have the biggest problem because unlike you, I have the 240KM/140MPH (Canadian) rather the US 140MPH/240KM.
Old Dec 22, 2003 | 05:41 PM
Pro
Guest
Posts: n/a
I still think, though, if you just scan the images to your computer (as black and white, or greyscale) and then edit the colors as needed, then just print off on a thicker type of transparency, you will be just fine...
Ill be doing this soon and ill take pics as I go.
