Porting intake base, plenum, heads
Old Oct 31, 2002 | 09:45 PM
whiteminqua's Avatar
Exclamation Porting intake base, plenum, heads
Hey, what bits do I need to port my aluminum base and plenum and my cast iron heads? I need a shopping list. Thanks.
Old Nov 1, 2002 | 01:23 PM
CRZYTRN-92Z28's Avatar
You will probabbly need:
a dremel tool w/ the bits
-drum sanding roll
-tapered metal cutting bit
-drum metal cutting bit
-tapered sanding roll
I think that should work
GL
Old Nov 1, 2002 | 02:28 PM
Sitting Bull's Avatar
No, a dremel won't work well.
You need an electric die grinder with a 1/4" collet.
Go to the link at the bottom of my sig. It has lots of info and pics showing just what to do with the heads.
Old Nov 1, 2002 | 03:29 PM
grinder....
I have an air operated die grinder. Are the kits from Summit or similar worth the $40.00?
Old Nov 1, 2002 | 03:34 PM
Re: grinder....
No.
As I said, go to my thread and read it. It shows you everything you need and how to do it, (except for the plenum but that is just port matching and hogging out anyway).
What more could you want?
Old Nov 1, 2002 | 06:22 PM
Go here if you need info on porting the plenum
http://www.gmtips.com/3rd-degree/dox...-port/port.htm
Its a pretty good site
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
