porting 305 heads
Old Jul 8, 2003 | 06:26 PM
Chris`s85Z28's Avatar
Question porting 305 heads
Well I have a set of 305 heads with a 1.94 valve now. Sittingbull told me to port them the only problem is I can`t afford the tools to do it. but I do have a Dremel tool with stone grinding wheels so I tryed it and it did a ok job at smoothing the ports but not really making the port bigger. now is it worth going to all the trouble smoothing and making all the ports shiny? will it make any power difference at all?
Old Jul 8, 2003 | 07:24 PM
Black6SpdTA's Avatar
Very little. The reason metal shines is because it's so smooth so it reflects the light. So if you make it shiney, then it's really smooth so it would let everything flow a little better which would make a little more power. If I were you I'd do it just because it looks cool when you're done and every little bit of power is good
-Rippin
Old Jul 8, 2003 | 07:39 PM
TunedPort 335's Avatar
DO NOT polish your intake ports. Leave those a little rough.
You can however polish your exhaust ones to a near chrome like finish if you want
Old Jul 8, 2003 | 07:47 PM
Good call. I saw 1.94 and I assumed he was talking about the exhaust ports.
Old Jul 8, 2003 | 09:20 PM
Slow91z's Avatar
I agree on a carb. car, because if not, on the way from the carb. to the cylinder if their is no turbulance then the fuel will not stay atomized...On the other hand on a port fuel injected car the fuel is only supended in the air for a short trip and the atomization occurs because of high injector fuel pressure therefore a slightly rough surface is not necassary...No I haven't dyno tuned both to see the diff, so I have no actual proof, and I don't want to start a argument...this is my opinion only.
Old Jul 8, 2003 | 11:02 PM
NTChrist's Avatar
Have you read the thirdgen.org thread (by SittingBull, a link to it is in his thirdgen.org signature) on porting heads?
It is FULL of answers to any question you could have.
Also, there is a guy in our area that is the 305 head G0D. He has flow'd his heads before, and managed to acheive similar #'s compared to a Vortec.
His SN is F-BIRD'88 on thirdgen.org, and his name is Russ. Nice guy. Never met him, but he's given me tons of advice.
I'm in the (slow) process of porting my 416's right now. I'm more worried about rebuilding my double pumper at the moment, tho.
P.S. do you still head out to Seaway on fridays? Are you going to be there next friday. btw I came too late to meet you that one friday like a month ago. I showed up at 9, and there was only a couple people I know there.
Old Jul 9, 2003 | 09:28 AM
What Dremel attatchment should be used?
Old Jul 9, 2003 | 11:53 AM
12Second3rdgen's Avatar
There is no such thing as a 1.94 exhaust valve on a small block chevy.
Old Jul 9, 2003 | 12:32 PM
1.5 x 1.94 heads. Someone told me once that the exhaust was always bigger than the intake, geuss not though eh
Old Jul 9, 2003 | 02:36 PM
Sitting Bull's Avatar
It is actually the opposite!
Yes, it is very hard to successfully port your runners and bowls with just a dremel. But if it has a 1/4" collet (or chuck) then just buy a few carbide cutters like the ones I pictured in my how-to. Click on the link at the end of my sig.
NT is right, Russ Patrick is THE 305 head guru and goes well out of his way to help anyone out with their projects. He is on the Tech/General forum at www.thirdgen.org almost daily.
Old Jul 9, 2003 | 04:39 PM
NT Christ yeah I still go to the cruise I`ll be there this fri at 6:00 to 8:30 or 9:00more than likley i`ll be parked by a 74 Nova SS so if you see a Nova SS and a Z28 togher it`s me oh yeah I`m also going to ridge fest on sunday
thanx for the replys my tool only has a 1/8" chuck maybe I can find mini cutters for it like the ones in sitting bulls sig, I`ll see what I can do with the dremel tool I`ll get a flex shaft too for it.
Hopfully I can get a grinder and some cutters by the winter and do the factory LG4 heads right
if you have any more words of wisdom I`ll be happy to here them
and sitting bull I checked out your link and it was pretty cool theres a couple things I want to try in it. thanx
Old Jul 9, 2003 | 05:45 PM
Have you thought of renting a die grinder? That's what I did. It was $50 for a week. Just enough time to get it done going 4 hours a day.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
