port and polish intake
Old Feb 4, 2003 | 06:29 PM
crakpotjoe's Avatar
some people i know do p&p work and they are doing my intake, my question is on stock intakes they have a divider between the two injectors inside the intake, if i have them cut that out like i see on some of the aftermarket intakes will it cause any air/fuel problems? TIA
Old Feb 4, 2003 | 07:48 PM
mrr23's Avatar
have them do what i did. or just buy mine. mine's even ceramic coated.
www.fl-thirdgen.org/mrr23-5.html
Old Feb 5, 2003 | 03:10 PM
guywidiroc's Avatar
You are going to love the difference this makes. If you port the entire thing correctly,the car will pull much harder in the highend.
Old Feb 5, 2003 | 05:09 PM
crakpotjoe's Avatar
yeah it should make a big difference. . . i have helped him do his upper and lower and throttle body on his mustang and its nice. we are also gonna do my heads after i get the porting kit in so it should be sweet. but anyway you dont think itll have an effect on the air/fuel ratio? thats the main thing im worried about cause we are cutting a big hole in the center comparitivly to a normal p&p job.
Old Feb 6, 2003 | 12:34 PM
87LS's Avatar
Nah you should still be ok, my friend did that and his runs STRONG, and it made a great difference in his motor. I think It just flat out runs better in idle and over all performance everywhere.
Old Feb 6, 2003 | 02:50 PM
crakpotjoe's Avatar
sweet thanks for the input. hopefully it will be what im hoping to get out of it.
Old Feb 11, 2003 | 10:20 PM
Matt87GTA's Avatar
Yep, the siamesed intake base is a good way to overcome the RPM barrier the TPI system inherently has. Here is a pic of what I did to my plenum and base:
http://www.mnfbody.com/memberpages/m...umPorting.html
I also have the SLP runners that have been worked over a bit too. I did all of the work with a die grinder and a single carbide burr. Hint: Use liberal amounts of gear lube on the burr
Dmonty
Jun 2, 2015 11:19 PM
Drtryder
Apr 22, 2015 04:17 PM
Killer94z
Jan 13, 2015 12:06 PM
Teal94V-6
Aug 31, 2002 09:21 PM
dansam
Jul 20, 2002 01:10 PM
