polishing question?
Old Jul 29, 2004 | 06:04 PM
kandied91z's Avatar
polishing question?
picked up a becool direct fit but it isn't polished. it is all aluminum and looks as if it would be rather easy to do a wetsand polish job with a fine grit.
anyone have suggestions? i would have bought the polished unit but at $400 more it didn't seem logical.
i used a similar process on my ac condenser and lines that were visible...as well as most things that looked like they were copper coated. just wetsanded with a few stages of paper and they turned out chrome....worked great, just curious if it would do the same for the radiator?
Old Jul 29, 2004 | 06:26 PM
IROC-T's Avatar
Re: polishing question?
Use a buffing wheel and start with White diamond compound ,and then Red rouge(sp?)
Old Jul 29, 2004 | 06:30 PM
kandied91z's Avatar
what type of shop would carry such products or would i have to special order the compounds?
Old Jul 29, 2004 | 06:53 PM
IROC-T's Avatar
Try Home Depot that is where I get it. They should have it in the tool area with the wheels. You can get a arbor that will fit a drillmotor if you don't have a stationary buffer,and you can get in tight areas with a dremal. Just don't try and go to fast or you will gum up the wheel an it will take longer,plus if you plan on doing more polishing (which you will)get three wheels one for each compound and one for just buffing. When you get it to the point you like it,finish with cornstarchand buff.
Old Jul 30, 2004 | 08:49 PM
slimdawson's Avatar
Uhhggg. I hate polishing. It looks good but I hate the maintenance. Corrodes too easily. At least it will look good until it rains
Old Jul 31, 2004 | 12:48 PM
95_LT1_6SPD's Avatar
my advice, clear coat it when your done.
Old Jul 31, 2004 | 12:58 PM
kandied91z's Avatar
clear coat isn't an option....it fades and dulls the finish.
Old Jul 31, 2004 | 04:20 PM
IROC-T's Avatar
Just keep it clean and dry,and use a little Mothers ,or similar aluminium polish.
Old Jul 31, 2004 | 08:36 PM
AutoRoc's Avatar
Good point Jeff! I cleared a brand new Victor Water pump before install and it definately took away that "new aluminum" look but I figured it would be easier to clean in the long run. Engine sprays oil onto said surface and baked oil into clear coat.. Yeah I'll be bead blasting it to get rid of the yellow candy look it has now...
Old Aug 1, 2004 | 11:12 AM
kandied91z's Avatar
yeah same thing happen to me on many engine parts, i cetainly understand....
Old Aug 3, 2004 | 10:18 AM
Ucantcme57's Avatar
I got your link...
http://www.eastwoodco.com/shopping/p...&keyword=13104
Order a catalog..
After polish then spray with...
http://www.eastwoodco.com/shopping/p...r+Coat+Barrier
I have used many of these guys products very good!!! they have dash and window restorers.. and all kinds of stuff...
Dmonty
Jun 2, 2015 11:19 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
dansam
Jul 20, 2002 01:10 PM
