pilot bearing
Old May 22, 2004 | 11:05 PM
Chris`s85Z28's Avatar
pilot bearing
would a 85 Z28 305 5spd have a pilot bearing in the clutch, I thought all std. tannys did but theres no bearing in my new clutch and I can`t rember if the old one had it or not??? I don`t think it did but I don`t need the put everything back toger and find out it suppost to have a pilot bearing.
Old May 22, 2004 | 11:29 PM
quickchicken's Avatar
yup, you need a pilot bushing in there. they can be bought at any parts store. be sure to test fit and grease it before ya instal it.
if ya ever need to pull one out ither rent a pilot bushing remover or fill the hole with grease or wet paper towels. find a bolt almost the same size as the hole, put it in hte hole and hit it with a hammer. the hydrolics will pop it out.
Old May 23, 2004 | 01:01 AM
trackbird's Avatar
You can buy a roller pilot bearing from Moroso or get one from a 6.3 liter diesel from a pickup truck built in the 80's. Or, you can stick with the bushing version.
Old May 23, 2004 | 10:21 PM
IMO i would go with a standard bushing. when a bearing goes it can take the input shaft with it from what iv heard. iv been using bushings with no prob.
Old May 23, 2004 | 11:13 PM
trackbird's Avatar
I always ran the bearings, never had a failure.
Old May 24, 2004 | 10:17 PM
I was blind the 1st time I looked it`s in there and it`s the bearing type.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
