Perfect 3rd Gen?
Old Jun 1, 2003 | 12:53 AM
  #16
LilJayV10's Avatar
Originally posted by ICEmanZ
my dream 3rd gen would be:
1989 IROC-Z (like new-low miles!)
Black
T-Tops
hooked up LS1(intake, exhaust, ignition, etc.)
beefed up T-56(shift kit, etc.)
17" Crome IROC rims
boom system
crap load of suspension mods and driveline mods to handle the EXTREME power and to provide GREAT traction!
maybe a little 50 shot
...to many other little mods to list, but those would be the major ones!
Dude.....how in the hell are you gonna shift kit a T56?
Old Jun 1, 2003 | 12:54 AM
  #17
Zepher's Avatar
Ya, I wanna see the answer to that one as well.
Old Jun 1, 2003 | 01:20 AM
  #18
Chuck!'s Avatar
Body and interior: 91-92 Z28 black on red, t-tops, 3" cowl, shaved door locks and door handles, eibach pro-kit, 18" hre 542s (9.5" front, 10" rear), white faced gagues, dual pod with a/f ratio and boost gagues, 98+ trans am seats.
Drivetrain and exhaust: 406 8.5:1 compression, edelbrock e-tec heads, miniram 3, dfi, custom grind comp cam, procharger, t56, pro 5.0, moser 12 bolt with 4.10s with a nice bear break kit all around, Hooker long tubes, dual 3" exhaust with dynomax bullet mufflers and x pipe, dual 4" tips (**** ground clearance!).
I currently have none of those parts.
Old Jun 1, 2003 | 02:03 AM
  #19
Dirt Reynolds's Avatar
Originally posted by 1985_305
If only i had a digi cam a few years back last year id have a pci of my dream 3rd gen my moms yes my MOM's turbo TA Black with ghost flames god i loved that car minor mods i was too young to know nething about the mods or even what a mod was all i know is that car flew but sadly it all came to an end when she got rearended by a drunk driver and broker her back so now she has to drive some big ford conversion van =(
Nice run-on sentence. Doesn't kill to insert a period here, and a comma there, does it?
What year was your "Mom's Turbo TA"? And did your Mom get the car painted black with the ghost flames?
Just curious.
Old Jun 1, 2003 | 12:31 PM
  #20
slayer6x6's Avatar
Old Jun 1, 2003 | 12:36 PM
  #21
AutoRoc's Avatar
Talking hehe
You'd need 3 cars to make your garage perfect and I'll share my dream with you guys. DREAM BIG!
Drag Car:
1987 IROC-Z Hardtop
Yellow paint W/ Big block hood/ black stripe
PAT Musi Built 707 Cubic Inch Chevy Rat(roughly 1200hp)
Nitrous Express Fogger 600-1200HP adjustability
Nitrous bells and whistles(progressive, purge, etc..hehe)
Turbo 400 trans
Fab9 rearend
tubbed with 33" meats out back, skinnies up front
Laundry on the rear bumper
-Basically Pat Musi's NMCA car minus a few hundred pounds. It would run 6.40's in the 1/4 mile at 230+mph...
Road Race Car:
1989 IROC-Z Convertible(my car actually)
8 point rollbar
Harnesses
17X10" ROH Rims W/ Hoosiers all around
Lowered 2"
Sam Strano built and tuned chassis setup
427 cubic inch SBC "Motown Block" based engine
WeldTech CNC'd Brodix 18 degree heads+intake
-Comp Cams solid roller well over .700" lift
lets shoot for 700hp all motor around 7500rpm, ok?
D&D Built T56 trans
Star Stage 3 clutch
14" Baer brake setup all around
2500lb weight<---whatever it takes carbon fiber, etc...
Cruiser/Weekend car:
1992 Z28 Convertible
Competition Yellow
Lowered 2"
Spohn treatment
Subframes for sure
custom Amp/Sub setup where the rear seats used to be
Amazing DVD and audio setup
Recarro Seats Heated/Air Cooled options
-Engine and trans?
200R4 Trans nicely built!
3.42 gears 3000 stall lockup converter
Ford 9" rear axle
-Stage 2 aluminum Block and headed 231 or 272 cobic inch Turbo Buick setup. Something simple but effective. Pump gas friendly around 700-800 hp if possible, 1000+hp tunability for a track outing with race gas. 25+ MPG fuel consumption at highway speeds
17" Rims, not sure what kind
Tires for every occasion
And a top that does not friggin leak..
thank you! Thank you!!
Old Jun 1, 2003 | 01:30 PM
  #22
doug791's Avatar
heres everything i want to do to my car:
1990 5.7L auto- hard top
colour scheme-silver with blue race stripes-interior is blue black and polished metal pieces
engine and drive train stuff
-slp cold air kit
-holley throttle body or tpis throttle body
-tpis mini ram with fuel rails
-tpis intake runners
-new heads (company undecided)
-internals so pistons, rings, valve stuff etc
-new cam (company undecided)
-slp headers (already on car)
-3" dual exhaust with cat's removed and a set up where i can switch from normal exhaust to straight pipes
-chrome tips yeah yeah
-richmond 6 speed overdrive tranny (unless i find i stronger 6 speed to put in not sure if there is one)
-B&M short throw shifter
-center force clutch?
-ford 9 bolt? i hear this is really good but i would need a rear end that would be really good for racing
-Carbon fiber drive shaft
-twin turbos one smaller one bigger so the smaller one starts on first and gives you and almost immediate boost and as the small one hits its max power boost the bigger one clicks on for a second of overlap and then the smaller shuts off and the bigger one carries me the rest of the way
suspension/tires/brakes
-koni phase 4 competiton use dual spring suspension
-17 " chrome rims
-low pro tires (forget brand my buddy was yelling at me that i should use a certain company i just forget which one)
-the biggest rotors and calipers i can fit on it with a one inch diffrent from front to rear obviously the bigger ones in the front
-polyeurithane bushings
ignition
-spark plug wires
-msd digital-7 igniton module fully programmable
-coil that msd reccomends to go with this
-same buddy just reccomended a specific spark plug i swear i forget everything he says
interior
-rip out whole dash concole etc and replace with something shiny that has a lot of gauges
-new front leather seats
-6 point harness?
-rip out back seats replace with a stereo system
additional
-move battery to rear (already done)
-rip out a/c
-subs, roll cage full stiffening treatment
-every connector for every tube and hose and wire etc with nice ones all blue and red
-fiberglass turbo hood
-fiberglass body panels?
-electronic cut off switch to kill all electronics if crashed (which will NEVER happen)
-anything that runs on a belt switched to electronic
im sure im leaving some stuff out but this is all i can think of at the moment
Old Jun 1, 2003 | 02:14 PM
  #23
stanghunter211's Avatar
Faq, thats alota good stuff there. I'm on my way!
Will
Old Jun 1, 2003 | 08:43 PM
  #24
ICEmanZ's Avatar
Originally posted by StealthElephant
i think it's a high end 6 speed manual tranny to hold more HP then a T56...what are those things good to? i can't find any info on them...price, etc
check that out, it'll give ya some useful info...
T-56
Old Jun 1, 2003 | 08:45 PM
  #25
ICEmanZ's Avatar
-slp cold air kit
-17 " chrome rims
ignition
-spark plug wires
interior
-6 point harness?
additional
-rip out a/c
this dude went all out...
HAHAHA.... it's all good though, i like what he's got
Old Jun 1, 2003 | 09:10 PM
  #26
colin911's Avatar
the zr1's already been done...
lol, old photoshop
Old Jun 2, 2003 | 12:22 AM
  #27
kandied91z's Avatar
Thumbs up
mine is in the garage.....
Old Jun 2, 2003 | 12:42 AM
  #28
AutoRoc's Avatar
Yeah Jeff's Dream ThirdGen changes everyday roughly so he follows suit accordingly...
Jeff I really want to see that car on the street soon. Maybe Woodward or something or the Downriver Cruise near me. See ya man.
Old Jun 2, 2003 | 12:51 AM
  #29
kandied91z's Avatar
Smile
wanted to come and visit with everyone when eric was in town but i just couldn't get it to start. denny, you wouldn't believe it....finally got the thing to run decent and it's a world of difference from what i had told you before. still need a rear and to find someone to help me dyno tune the old OBDI now that the engine is broken in. as soon as i find a good supplier of coilover springs to lower the car back down i think i'll quit.
for awhile!
Old Jun 2, 2003 | 10:05 AM
  #30
jeff87formula's Avatar
1992 slp firehawk . "t-rammed" 350 , t56 , and a 13 second timeslip
http://members.tripod.com/~Proformula/firehawk.html
