Parts from a 305 to a 357
Old Mar 19, 2004 | 11:11 PM
zrs's Avatar
zrs
What parts can I use on my current 305 that can be reused on the 357. I have a 357 sbc with vortec heads.
Old Mar 20, 2004 | 08:41 AM
Dave89IROC's Avatar
front accesories, flywheel, oil pan, valve covers(if centerbolt) and bolts(you can use your manifolds, but i wouldn't, if you have headers, great)
Old Mar 20, 2004 | 07:50 PM
zrs's Avatar
zrs
TY for the reply. What would you recommend to use for the damper?
Old Mar 21, 2004 | 12:32 AM
Dave89IROC's Avatar
I forgot, you can use your damper too, though you might want to get a new one
Old Mar 21, 2004 | 12:38 AM
zrs's Avatar
zrs
I was thinking of replacing the damper as welll with a new one but undecided as to which brand to get.
Old Mar 22, 2004 | 05:44 PM
slow_roc's Avatar
i would get one off a o.e. 350 if you are using a o.e 350 crank so the balance wouldnt be as much off if you use your 305 one (since i belive theres a size difference between the 305 and 350 balancers) unless you plan on rebalancing your hole rotating assembley then maybe go aftermarket if cost isnt a issue
F'n1996Z28SS
Aug 23, 2023 11:19 PM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
