overheating
Old May 15, 2004 | 04:48 PM
cralarcon_IROCZ's Avatar
overheating
I want to see if anybody can help me out with my overheating problem. my fans dont seem to want to stay on....when i turn on the car one turns on when cuts off. i took off the fans and put direct power to them and they turn so i dunno. i'm guessing its either my relay of the temp senor. its on a 89 iroc 350ci
Old May 15, 2004 | 11:59 PM
90rocz's Avatar
How hot??
The fans aren't designed to stay on...
Are you sure it's overheating??gage senders do go bad..
Old May 16, 2004 | 04:15 AM
well according to the temp gauge it'll get up to 260. now i havent checked the actual temp of the coolant in the radiator so i dunno. but when it hits 260 the fans still dont turn on. from what i have researched one is suppose to turn on at 220 and 240...so i mean something isnt right. maybe the temp senor in the head is faulty
Old May 16, 2004 | 06:14 AM
aklim's Avatar
The fan, one of them anyways, is designed to come on at a certain temp. Get a scantool and see what temp the ECM sees. Compare it to the temp at the gauge and see if there is much of a difference. The sensor in the front of the manifold is what the ECM goes off. The sensor between #1 & #3 exhaust port on the cylinder head is what your gauge goes off. Those may vary.
Old May 16, 2004 | 01:09 PM
what type of scan tool could i use to determine the temp the ecm is reading?
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
