Open element filter on my TBI ?
Old Sep 2, 2002 | 10:53 PM
OutLaw305's Avatar
Post Open element filter on my TBI ?
I was looking at open element filters at pep boys today and was thinking how much better it would be than my stupid stock restrictive air box i have on my 92 RS right now. While reading the box it mentioned that it was for Carb aplications only. How would i go about fitting it on my tbi, would it still bolt right up.. or what fabricaitons might i have to make?
thanks
mitch
Old Sep 3, 2002 | 10:59 AM
Chuck!'s Avatar
Post
http://snflupigus.tripod.com/step1.htm
It dont get more in-detail than that Wait till you hear the noise it makes!
Chuck Kulchar
1991 Camaro RS LO3 A4
Now with 100% more Vortec heads!
Old Sep 3, 2002 | 08:33 PM
OutLaw305's Avatar
Post
wow, thats a great walkthrough. thanks fo rthe info.. my car will be breathing much better very soon.
Old Sep 3, 2002 | 08:43 PM
92_RS_305's Avatar
Question
What kind of noise does it make? b/c i'm planning to do the same thing to mine.
'92 RS w/ 305 TBI, *wrecked right now* Flowmaster 80 series, K&N Filter.....more mods to come.....gotta save up the cash first though
Old Sep 4, 2002 | 10:30 AM
91RS5speed's Avatar
Post
It should make a big differance. The stock air cleaner is pretty small. Only problem is after you drive for a little while and the engine gets hot you will start sucking in hot air. You might want to look into finding a duel snorkle air cleaner.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Sep 4, 2002 | 11:00 AM
NJ SPEEDER's Avatar
Post
hot air or cold air isn't really teh point of an open element. the stock air box has so many restrictions in it that it si the volume of air that is at issue. even the dual snorkel can not allow in as much air as an open element.
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Sep 4, 2002 | 05:21 PM
85_tpi_350's Avatar
Lightbulb
Old TBI truck trick...
Remove the lid from the air cleaner, flip it upside down, and put it back on the truck. It opens the airbox up dramatically, and it's a bit cheaper than shelling out thirty bucks for an aftermarket air cleaner. Provided the hood will shut on it this way, I've never tried it on a Camaro, you're in the clear. As for the hot air dilemma, it's not that big of a deal. Yes, colder air will make it run better, but the sheer increase in volume more than makes up for this.
Also, if you yank the stock assembly for an aftermarket piece, make sure you plug off the vacuum port at the base of the TBI with a vacuum plug, readily available from Auto Zone, that way you have the least possible potential for a vacuum leak down the road.
Also, everyone swears up and down that K&N's are the greatest thing since sliced bread. Honestly, I've had one on two different vehicles, one with a 4-bbl 350 and the other a TBI 350 and I didn't notice an appreciable difference on either. Go to the paper 14x3 and save $30.
Lastly, the extra noise you encounter from the open element breather is the throttle bodies pulling in air, it isn't that loud, not even under WOT, especially if you have an aftermarket exhaust. Fuhgeddaboudit.
Horsepower is like cheese, you can add it to ANYTHING and it's a little more enjoyable.
-Posey
oldschool
Feb 9, 2016 09:21 PM
May 21, 2015 01:04 PM
charchri4
Apr 14, 2015 06:40 PM
99TransAmWS6
Aug 8, 2002 09:19 AM
