one little wire..
Old 09-01-2005, 06:40 AM
LoudmouthSS's Avatar
one little wire..
hey i found this 1 little wire...wondering where it goes...its right next to the est timing bypass wire
heres a pic..
http://memimage.cardomain.net/member...1_115_full.jpg
please tell me its something important (hopefully something to do with the ignition or something)....b/c im running out of ideas on this ignition problem im having..
LoudmouthSS is offline
Old 09-01-2005, 10:26 PM
Re: one little wire..
anybody?
Old 09-02-2005, 08:13 AM
Ben91RS's Avatar
That's the fuel pump test/prime connector. It's just what you use to check the fuel pump and wiring if you suspect something is wrong with either two. You would just apply 12 volts to that connector and the fuel pump should run.
Ben91RS is offline
Old 09-02-2005, 09:40 AM
thank you
Old 09-03-2005, 01:46 AM
iansane's Avatar
From everything I've read the fuel pump test wire should be on the drivers side, not passanger side.
Mine is, and was on my old 87 as well. Both TPI cars.
iansane is offline
Old 09-03-2005, 09:05 AM
i heard from thirdgen.org they moved it around throughout the years
Old 09-05-2005, 09:08 AM
slimdawson's Avatar
It was also in that place on my 91RS.
slimdawson is offline
chris4813
10-27-2012 06:04 AM
97superchgedz28
05-12-2012 12:12 AM
SmokeyBlaZe
01-08-2010 03:04 PM
z28camaro1090
02-09-2009 08:49 PM
Lost
01-02-2006 10:08 AM
Quick Reply: one little wire..
