Oil On Spark Plug 1 and 2
Old Dec 3, 2003 | 02:01 AM
Kuruption562's Avatar
What does this mean? I know its nothing good.
Old Dec 3, 2003 | 02:13 AM
kevin 2.8's Avatar
oil is leaking past worn valve guides or piston rings causing hard starting misfire and hesitation
how many miles on car? are they fresh plugs? does car smoke on startup and/or does the exhaust just smell ?
you didnt squirt oil into the cylinders after storage and forget to change the plugs? -longshot
Old Dec 3, 2003 | 02:19 AM
It Reads 50,7xx. I got it at 47k Miles and the last ownder said it was rebuilt 47,000 miles ago, so he was saying when it was rebuilt the odometer was reseted (can it be reseted?) The Spark Plugs have about 2,500k miles on em and they are NGK's. As i was replacing the wires tonight i saw that 1 & 2 had oil on them. Will it take alot of work and $$ to fix my problem?
Old Dec 3, 2003 | 02:39 AM
aklim's Avatar
Where on the plug? If you see it without removing the plugs, it is probably a leaky valve cover. If you remove the plug and see it, it could be a leaky valve stem seal.
Old Dec 3, 2003 | 02:46 AM
kevin 2.8's Avatar
yes the odo can be reset with a screwdriver, if its digital with a laptop, or you can put in a new one with 0miles on it
Old Dec 3, 2003 | 03:05 AM
I did not take the plug out. The Oil Was on the White part of the Spark Plug. What to do now?
Old Dec 3, 2003 | 03:38 AM
kevin 2.8's Avatar
sorry i thought you meant on the electrode spark part of the plug was the oil deposits
Old Dec 3, 2003 | 09:06 AM
aklim's Avatar
There are 2 white parts, FYI. The part inside the combustion chamber has a porcelain (white) part too. In your case, it is oil dripping past the valve covers or somethig someone spilt. Clean it with brake cleaner when it is cold and observe what happens from week to week.
Old Dec 3, 2003 | 12:03 PM
Clean inside the threads where the spark plug goes with brake cleaner? Should i buy those 2 new spark plugs?
Old Dec 3, 2003 | 12:47 PM
aklim's Avatar
Brake cleaner will work fine. Don't buy new plugs till you solve the problem since you have both valve covers to change. You did say #1 and #2 which are the first plugs facing the front on both sides.
Old Dec 3, 2003 | 10:42 PM
97WS6SCharged's Avatar
Isn't it a felony or something to do this? I'm pretty sure it's illegal.
Old Dec 4, 2003 | 01:27 AM
IROC-T's Avatar
Clean the area from grease and oil,then change you valve cover gaskets or tighten your check to make sure the covers are tight. If when you pull the plugs they should be a light coco color.
Old Dec 4, 2003 | 01:53 AM
What does it take to get to my Valve Cover GuardS?
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
