Oil pressure sending unit
Old Dec 28, 2003 | 09:17 PM
Zrated383's Avatar
Hey...can you guys tell me where the oil pressuring sending unit is on an 1989 IROC-Z 350TPI? Thanks.
Old Dec 28, 2003 | 09:43 PM
90rocz's Avatar
Above the oil filer going into the block, sticking out toward the side of the car.
Old Dec 29, 2003 | 09:54 AM
aklim's Avatar
I believe it is a tube about an inch in diameter and about 3 in long with 2 wires coming out of it.
Old Dec 29, 2003 | 10:32 AM
l_bilyk's Avatar
mine is behind the distributor
but i think they changed that in 87 or 88 for vettes and the followin year for f-bodies
Old Dec 29, 2003 | 04:45 PM
Dave89IROC's Avatar
I have both on my 89, the one by the distributor is a sender for the gauge and the switch for the fuel pump, dont know what the other one is?
Old Dec 30, 2003 | 03:40 AM
raul.garcia's Avatar
oil sender
My 88 350 TPI has the oil gauge sender to the right of the dizzy (driver's side,) the other sender located above the oil filter is an oil pressure switch call the "Fuel Pump Switch," if there's not sufficient oil pressure to keep the switch closed then when the fuel pump relay times out the fuel pump stop pumping.
Old Dec 30, 2003 | 05:24 PM
90rocz's Avatar
The sender for the gage is larger than the fuel pump cut-off switch. The FPCOS is usually on the back of the block near the intake, and the oil gage sender is the above the filter. The gage sender looks like a cylinder about 3" long and a little bigger around than a quarter.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
