Oil leak
Oil leak
OK i hae a 1989 TPI350 and it seems to have a leaky valve seal, on start up it puffs smoke from the drivers side exhaust (its true duals) so that leads me to believe it is a valve because it does not smoke after start up. Does anyone think any different as i am not a mechanic, and if it is the valves how much would this normally cost me to fix at a shop and can it be done with the heads in the car?
Re: Oil leak
Are you mechanically inclined? It's not that hard if you have an air compressor, valve spring compressor and can adjust your valves. You just need to pressurize the cylinder your working on, compress the valve spring, pull the valve locks out, pull the spring off, then replace the valve seal. Then reverse the steps to put it back together. I've used the end of a compression tester on my air compressor line to screw into each spark plug hole when i've done them. You could pick up a set of umbrella type seals at Napa. It's really not a major job and they can be done with heads on the car easily.
Ken R.
Ken R.
Re: Oil leak
Ok thank you for helping out, i dont have an air compressor so i may just see how much a mechanic will charge to do it for me - if it doesnt cost me an arm and a leg i may have him install some new rockers.
Re: Oil leak
Yea im going to deal with it for now, its not fatal but it has inspired me to update. Im going to buy assembled Vortec heads, along with a vortec style intake base, and some 1.6 rockers. If i get the 1.6 rockers do i need longer pushrods or anything special? I'm not very knowledgable on heads so i may need help picking the right combo.
Re: Oil leak
Rarely do you get away with just dropping valve stem seals in it and it lasting like that… usually the seals start leaking when there is enough play in the valve stems to egg out the holes in the seals
Re: Oil leak
why not buy brand new aluminum heads that work with your base for around the same cash as Vortec's and a vortec base?
Re: Oil leak
edelbrock doesnt make any heads that fit a non vortec emissions equiped TPI system anyway it seems.
they are about $1100 and install yourself
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
