O2 conversion
Old Dec 7, 2006 | 05:58 PM
Thanatos6's Avatar
O2 conversion
Hi everyone, I am looking for a way to convert from a one wire to a three wire O2 sensor for my brothers '91 with an LO5. I'm not sure where to start on this one.
Any help is appreciated.
Thanks!
Old Dec 7, 2006 | 08:47 PM
ws6transam's Avatar
The only difference between a one-wire and three-wire O2 sensor is that the three-wire has a heating element. You can trigger off the fuel pump circuit if you wish, by adding a $12 relay from NAPA that routes battery power to the O2 heater whenever the fuel pump circuit goes active.
Old Dec 7, 2006 | 09:20 PM
Thanatos6's Avatar
That may work
The heater was what I was going for.
So pretty much, splice the sensor wires toghether and hook the other two to a battery source?
Thanks for the help
Old Dec 7, 2006 | 09:26 PM
ws6transam's Avatar
One wire is for the O2 sensor output. The remaining two wires are for power and ground. I dont think it matters which one is which, so long as you get the O2 signal wire correct.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
