Z28 TPI engine problem
Old Dec 4, 2006 | 09:57 AM
busterman88's Avatar
i'm having a problem i washed my engine with a pressure washer after 10 minutes i started the car and it started fine but when i accelerate is sputters and doesn't get to high rpms only when you are slightly touching the pedal. any ideas i all ready cleaned the distributor cap and the coil but still does the same.
Old Dec 4, 2006 | 10:56 AM
87DJP2001's Avatar
Let it dry out overnight then try it. I learned that same lesson also, don't spray water on these engines they have too many wires.
Old Dec 5, 2006 | 10:19 AM
its been four days since it happened. im thinking i probably cracked the block. i'm also wondering why did the engine used to shoot out steam from the guide tube for the dipstick. the steam problem i noticed since i recieved the car.
Old Dec 5, 2006 | 05:36 PM
fireball451's Avatar
Probably got a sensor too wet.
The steam could just be the internal gasses and fumes.
Old Dec 5, 2006 | 06:10 PM
mako350Z28's Avatar
Change your distributor cap. You got water under it. I have done this twice before with different cars.
Old Dec 5, 2006 | 09:20 PM
1987IROC350's Avatar
Like "mako350Z28" said. You have to remove the distributor cap and dry it out. It will not dry out on its own. Might as well replace it if its old.
Old Dec 7, 2006 | 11:49 PM
the cap and the coil were replaced after this happened thinking that was the problem. now the car is starting to return to how it used to be with a slighly decrease in power. now what i cant stand is the oil leaking thru the dipstick tube. i was told that it was a pcv valve that was clogged. Still hoping it regains its power back.
Old Dec 8, 2006 | 10:55 AM
mmmchickenboy's Avatar
Originally Posted by busterman88
i'm having a problem i washed my engine with a pressure washer after 10 minutes i started the car and it started fine but when i accelerate is sputters..
pressure washing TPI engines is risky business. this same thing happened when my dad decided to clean his 33k mile '87 Z a couple years back. it was never the same.
Dec 31, 2014 02:21 PM
4586
Dec 6, 2014 05:20 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
