is that normal?
Old Dec 4, 2002 | 10:59 AM
Iratate4k's Avatar
Question is that normal?
okay, after getting out the bitch mobile I noticed upon walking into the house that there was a hissing sound that sound as if the tire was leaking but it wasnt. So I go to get a look close and I see it wasn't coming from the tire at all, no, in fact it sounded as if it were coming from the upper left side of the hood (looking at it from the front). But after a few seconds the sound starts to fade away and I really havent gave it much thought but I thought since I'm on this site I might as well ask to know wut it is....
Old Dec 4, 2002 | 12:16 PM
Aaron91RS's Avatar
On what car? My electric fuel pump has kept running awhile and whined in back and made funny sounds up front. Thats on a carb car though.
Old Dec 5, 2002 | 05:08 AM
BROKKANIC's Avatar
Suspended
Residual pressure from your air pump? Could be a number of things.
Old Dec 5, 2002 | 06:53 AM
Lars's Avatar
Brake Booster vacuum line/connection
Old Dec 5, 2002 | 07:37 PM
stevem's Avatar
if you have a/c it could be the system equlizing the pressure inside
Old Dec 6, 2002 | 02:18 AM
oil pan 4's Avatar
If it is the A/C equaling out that's not good it's called migration.
I would check vacuume lines, do you have power breaks after you turn off the car?
You should be able to push the break down a few tmes before it turns into a brick.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
