no heat in my LT1 powered Z, hellllp!
Old Dec 20, 2003 | 07:15 PM
  #16
slimdawson's Avatar
Why do they even have bypass valves? I didn't have one and I ran both the hoses from the pass side directly to the heater core.
I don't remember having the vacuum problem. I have heat at idle. I did take the vacuum canister off though so the car has to be running in order to change the hvac controls. I did have to play around with the hoses a bit.
Check for a faulty thermo as said earlier. It will cool off quick driving and never make decent heat.
Old Dec 21, 2003 | 12:48 PM
  #17
sinner's Avatar
i think the t-stat is ok cuz i have already changed it. i didnt know that i needed to use both of the outlets on the passenger side of the water pump. i am going to try running the lines to the heater core without the bypass valve.
so then the question is, why does the thirdgen even have the bypass valve?
Old Dec 21, 2003 | 03:42 PM
  #18
Zepher's Avatar
to keep extra heat from inside the car and to bypass the coolant if the heater core leaks, but that doesn't seem to work since my friends 90 Camaro has the bypass valve and he still had coolant leaking into his car.
Old Dec 21, 2003 | 11:26 PM
  #19
cronsformula350's Avatar
yeah the bypass valve, just likes to break alot, When I bypassed my throttle body coolant passage, the inlet side of the valve, just snapped off, coolant shot everywhere. And what was funny, was it was just before I was going out to a carshow, I guess it was good timing, but it is nice if your heater core breaks, my friend has a 91 z, and he wasn't as lucky, he had coolant everywhere when his heater core failed, sucked to be him.
Old Dec 21, 2003 | 11:29 PM
  #20
Zepher's Avatar
That is exactly how my bypass valve broke, while I was doing the TB bypass. I guess they get really brittle from teh heat and age.
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
ro2207
Dec 4, 2014 06:18 PM
XtremeLt1
Sep 13, 2002 08:50 PM
Omega9
Aug 2, 2002 12:33 AM
