need a stronger rear
Unless you've got a solid 9 second car cutting sub 1.4x 60ft times, go with a 12 bolt.
Check out the gears section on LS1tech.com and read all about the 12 bolt vs. the 9" vs. the 60....I ended up going with a Moser 9"....I didn't need a custom sway bar and my Baer brakes work perfectly....
Tbyrne is running a deal on 12 bolt rears right now. $200.00 off.
carguyshu
Jan 22, 2017 11:19 AM
May 1, 2015 01:14 PM
importkiller94
Jan 17, 2015 09:03 PM
