need a stronger rear
Old Aug 13, 2007 | 11:06 PM
BoostedThrills's Avatar
anyplace running discounts right now
not sure what to get 12 bolt ford 9 or a dana 60
I'm afraid the TTA makes so much power that it will break a 12 bolt
Old Aug 14, 2007 | 11:52 AM
Marc 85Z28's Avatar
Not very likely with your setup and an automatic trans. The 9" and Dana 60 are heavier, eat more power, need custom sway bars, and usually require you to use non-GM brakes.
Unless you've got a solid 9 second car cutting sub 1.4x 60ft times, go with a 12 bolt.
Old Aug 14, 2007 | 03:59 PM
Rice Killer87's Avatar
What Marc said. if you break the 12 bolt,buy a lottery ticket.
Old Aug 22, 2007 | 12:00 PM
Z28SORR's Avatar
Originally Posted by Z28Roxy
The Dana is heavier but it's more efficient (less parasitic loss). Also at least for 4th gens it's cheaper than the 12 bolt, though not significantly.
Not a "Dana 60"!!
Old Aug 23, 2007 | 12:21 PM
Anniversary-Z-man's Avatar
Check out the gears section on LS1tech.com and read all about the 12 bolt vs. the 9" vs. the 60....I ended up going with a Moser 9"....I didn't need a custom sway bar and my Baer brakes work perfectly....
Old Aug 23, 2007 | 12:27 PM
87DJP2001's Avatar
Learn how to drive and you wouldn't be breaking rears.
Old Aug 23, 2007 | 12:50 PM
shock6906's Avatar
Tbyrne is running a deal on 12 bolt rears right now. $200.00 off.
HarleyZ28
Oct 5, 2015 06:23 AM
May 1, 2015 01:14 PM
jj_burchiel
Mar 5, 2015 07:05 AM
importkiller94
Jan 17, 2015 09:03 PM
