Need some major advice
Old Jul 12, 2005 | 11:30 PM
f-bodybuilder's Avatar
Just moved down to cali with my camaro. It's got and L98 w/ ported and polished heads, SLP cam, TPIS big mouth base, large tube runners and 52MM throttle body, Edelbrock shorties, and a lingenfelter stall. However, it's got low oil pressure, and on the move down to cali the tranny went out, leaving me with only 1st and 2nd gear. Is it worth it to swap out the block and tranny, or should i just part it out? I'm thinking about selling it as-is. How much do you guys think i could get for it? After the move, i don't have the resources needed for an engine swap.
Old Jul 13, 2005 | 11:25 AM
MyShibbyZ28's Avatar
Re: Need some major advice
For the low oil pressure just check your oil and if it's low, add some, problem solved. If not then there's other problems. And about your transmission, I'm assuming it's automatic seeing they never put sticks in 350's. If you were to sell it "as-is" you wouldn't get much with a blown tranny. Just get a new transmission and you'll be set, you don't need a whole new engine or anything.
Old Jul 13, 2005 | 12:16 PM
nj85z28's Avatar
totally agree with that. i wouldnt recommed parting her out already
Old Jul 15, 2005 | 09:07 PM
OK, so not having the actual tools to swap out the tranny will probably cost me....$1500+ for the job + tranny itself. I honestly doubt i'd be able to get at least 1500 more just for having the tranny swapped out. And yes, the engine components are causing the low oil pressure.
Old Jul 15, 2005 | 10:34 PM
Lynk's Avatar
It should be pretty easy to find a tranny at a junk yard or on ebay, You have a 700r4, you can probably get one for $200-$300 then find a greasy little corner shop and they will probably install it for another $400-$500, I am east coast so the price may be a bit off. An 88 Iroc in good condition goes for between 3,500 and 5,000 on ebay usually. One with a blown tranny you'd be lucky to get 2,000, so I'd swap it.
Old Jul 18, 2005 | 02:16 AM
Solidous_Snake's Avatar
What part of Cali did you move? What kind of Camaro? I might possibly buy it from you. Let me know.
Old Jul 18, 2005 | 11:03 AM
iansane's Avatar
How is the intake/cam/head stuff causing low oil pressure?
Old Jul 18, 2005 | 12:51 PM
OK, I'm not sure if components was the right word.....Anyway, the engine itself, i think tired main bearings causes this, is having low oil pressure.
I'm located in Atascadero CA, right by San Luis Obispo. The car is an 88 IROC-Z.
Old Jul 18, 2005 | 01:12 PM
iansane's Avatar
Ooooh, makes more sense now. Is the pressure low all the time?
Old Jul 18, 2005 | 01:14 PM
No, only at low RPM's when the temp is up.
Old Jul 18, 2005 | 01:51 PM
RedIrocZ-28's Avatar
How low? 20psi at idle with an engine temp of 210 is acceptable. Thats what mine runs currently and I am about a quart low, or however much drained onto my garage floor when adjusting the rockers.
Old Jul 18, 2005 | 02:09 PM
iansane's Avatar
That's about what mine hovers at when warmed up and I'm about half a quart low right now.
How low is low?
Old Jul 18, 2005 | 02:19 PM
Mine's at about 15. I was always under the impression that it should be at 30....
Old Jul 18, 2005 | 02:32 PM
According to the GM maintenance manual anthing under 20 is suspect. It should be 20psi or higher I believe. Anything under that is usually a sign of the main bearings, rod bearings, and cam bearings going bad.
Old Jul 18, 2005 | 02:47 PM
How long do engines generally last once the bearings start going bad?
