Need help/opinions..car is running EXTREMELY rich!
Old Jul 9, 2004 | 07:57 AM
95redvert's Avatar
First off I just installed a Minirammed 383. All the details of the motor are below. Since we first started it up it has been rich. Which we expected. But now that I have played with the tune, just a little now mind you, it is still rich. And when I say rich I mean burn the eyes out of your head rich. How should I correct this problem, keeping in mind I do not have access to a custom burner for my chip or a dyno. Any and all help would be greatly appreciated!
- 1988 Trans Am GTA: 383 stroker - ATI damper, Billet Underdrive pullies, Eagle 4340 Crank, Eagle H-beam rods, Cloyes Double Roller Timing Chain, Stewart High Flow Water pump, Weisco Flat-top pistons, LT4 Hotcam, WP Torquer S/R heads (ported and plained), 1.6 GMPP roller rockers, GMS Adjust. MAF, TPiS Miniram, TPiS Prom, 24lb SVO injectors, BBK 52mm tb, MSD 6A, MSD Pro Billet distributor, MSD 8.5mm wires, MSD coil,March underdrive pullies, K&N cone filter, Edelbrock Jet Hot Ceramic Coated headers, !Cat, Flowmaster 3" cat-back, TCI 3000 Converter, B&M power clutch pack, B&M shift kit, B&M servo, SFC's, Spohn LCA's, Spohn LCA brackets, Lakewood DS loop, Eibach Sportlines, Lakewood Panhard Bar, KYB shocks and struts, Nitto 555R's. And NX EFI Wet Kit, 75-150hp just for giggles!!
Old Jul 9, 2004 | 09:31 AM
onefastgta's Avatar
You need to adjust the chip. The 24lb injectors along with the cam and intake are making problems for the stock chip.
You need to log some data at idle for the blm's. I have a similar set-up and can get you closer on the .bin if you have some scanner data to make changes with.
Without seeing what the computer/ecm is seeing, you are in the dark.
Old Jul 9, 2004 | 11:15 AM
95redvert's Avatar
Well I have a TPiS chip, and it is "supposed" to be programmed for the hotcam etc.
Old Jul 9, 2004 | 02:40 PM
aklim's Avatar
Go to www.fasterproms.com and they will take your specs over the fone. Have them lend you their Diacom system and they can fine tune the chip so that it is truely custom to your setup and not an off the shelf. Used them and had good luck with them over the years. $350 for the first burn and $150 for burns in the future. A burn is considered complete after all the tweakings are done and that is when you are charged,
Old Jul 9, 2004 | 05:15 PM
aklim's Avatar
Word is that Ol Myron Cottrel is not the best person to get help from if there is a problem. Besides, each car is different so how did he happen to know what would happen with your car? Or did he just make a chip for cars with those mods, in general? I wouldn't trust any chip that wasn't made custom for that car because they might pull out a whole bunch of power just to make sure you don't blow it up and blame them. Either dyno tune it or take readings and make sure it works but this "one size fits all bothers me.
Old Jul 10, 2004 | 12:48 PM
RedIrocZ-28's Avatar
Do not buy an over the counter non custom chip... ever.
I've been tuning for quite some time now. I'd like to think that what I have invested far outweighs paying for a custom chip. I have learned lots of things about the motor just from tuning.
Bottom line, get a custom one done. End of story. You can't adjust anything on the motor to make it run correctly on a stock chip with your combo.
Old Jul 10, 2004 | 01:22 PM
Stephen 87 IROC's Avatar
Turn your fuel pressure down and try again.
Old Jul 10, 2004 | 01:35 PM
No no... if he turns the fuel pressure down its gonna effect adversely the wide open throttle fueling. He may pop a hole in a piston if he runs it too lean. He's gonna have to crank it down about 4psi which is about 10% less fuel at WOT. Dunno about you but running a 383 with big heads and running 10% less fuel than a stock chip at wide open throttle isn't somthing that I want to experiment with a $4000 motor. Hell he may be running 14:1 AFR at Wide open... thats scarey to say the least.
Old Jul 10, 2004 | 04:45 PM
Bristol's Avatar
Be very careful not to run it too much without a better tune cause you wash the rings and not set the rings properly. I have a good friend who recently has gone through this.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
Antz97ZNJ
48
Jun 20, 2002 06:09 PM
