NEED help choosing cam for tow truck
Old Nov 26, 2007 | 09:26 PM
pyro719's Avatar
I just got a 81 chevy 1 ton 4x4 holmes 440 wrecker and the 350 is lacking power, I got a set of edelbrock performer heads and intake for it, It already has long tubes and an accell super coild hei, Just wondering what cam you guys would recommend for this tow truck?
Old Nov 27, 2007 | 02:29 PM
Rice Killer87's Avatar
Call Comp cams tech line.
Thats your best bet man.
Old Nov 27, 2007 | 05:11 PM
mdacton's Avatar
any cam company should be able to help you......I don't care for comp
Old Nov 27, 2007 | 05:53 PM
AutoRoc's Avatar
Edelbrock has cams for their head/intake combinations. Maybe check those out, they're all pretty mild and meant to be street driven. Maybe convert it to hyd. roller? Not sure what your goal is here.
Old Nov 28, 2007 | 07:07 AM
pyro719's Avatar
I would like to have 400 ftlbs by 2500 rpm's its a tow truck
Old Nov 28, 2007 | 11:02 AM
takeoffeh's Avatar
Cams...
The other guys advice on calling a cam company is good. What I can tell you is, if it's Comp Cams you're looking for, I would use either the:
XE-256 (OR) XE-262-4x4
The 256 is the straight Xe cam while the 2624x4 is the Gruntier version.
Old Nov 28, 2007 | 11:57 AM
Marc 85Z28's Avatar
Keep the duration below at or just below 220 degrees, with a traditional split. LSA no wider than 110. Once you meet those specs, pick the cam with the most lift.
Old Nov 28, 2007 | 09:23 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Since this isnt about thirdgens, I have to lock it.
rideordie
Nov 5, 2019 04:52 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BPS
9
Mar 5, 2015 10:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
