Need help with a 92 Camaro (please)
Old Jun 10, 2002 | 01:40 PM
SS2246's Avatar
Post Need help with a 92 Camaro (please)
Dad has a 92 Camaro with the computer chip key system. He disconnected the battery for a few months. Now there is no power to the car. I think it has to do with the anti-theft system. Is there a way to reset it? Is he going to have to tow it to the dealership?
Many thanks for your help!
Old Jun 10, 2002 | 05:02 PM
A's Avatar
A
Post
Disconnecting the battery shouldn't give you VATS problems... Is there no electricity at all? or is it just when you turn the key to start, nothing happens?
How the VATS (Vehicle Anti-Theft System) works is that computer chip looking thing in the key is just a resistor. The resistors range from 1 to 15 ohms if I remember right (Mine is 12 ohms) and if the VATS does not sense the correct resistance from that pellet in the key, then it will not allow the ignition, the fuel pump, or the starter to function...but all the lights and radio and windows and such should still work.
If your problem IS the VATS, Eckler's sells a kit to bypass it completely. I think that kit is around $20 or so...
Good luck!
Old Jun 10, 2002 | 06:42 PM
funina91ss's Avatar
Post
did you make sure the battary was charged? they can go dead just sitting,even thought it has not been used also check the fuses. Hope this helps.
L8R Sean
Old Jun 11, 2002 | 09:39 AM
sahlomonic's Avatar
Post
Yeah, check the battery first. If they sit for even a few weeks sometimes they can lose their charge.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
