need advice
Old Feb 28, 2004 | 10:47 AM
SERPENT99's Avatar
need advice
I have 245/50-16 on the front, I want a taller tire in back, maybe a little wider, any ideas? maybe a 255/60
Old Feb 28, 2004 | 11:03 AM
Marc 85Z28's Avatar
For your stock 16x8 wheel, go with a 255/50r16 tire for a slightly wider tire. The 255/60 will most likely rub, and will throw your speedometer by a good bit.
Old Feb 28, 2004 | 07:41 PM
aklim's Avatar
To what end? 10mm more of rubber is not that much more traction and you have to get gears and maybe even a speedo adjustment box to fix the speedo reading. Not worth it, IMO.
Old Feb 29, 2004 | 09:44 AM
Marc 85Z28's Avatar
255/50r16 vs 255/60r16
You understand tire sizes right?
Stock 245/50r16 are roughly 26" in diameter.
255/60r16 are roughly 28" in diameter.
Old Feb 29, 2004 | 10:20 AM
SERPENT99's Avatar
I understand the sizes. I want to fill up the rear wheelwell a little
Old Feb 29, 2004 | 11:59 AM
aklim's Avatar
I do understand it but going from a 245 to a 255 is only gaining 10mm. Yes you get a taller tire but not sure why it is benificial to your case.
Old Feb 29, 2004 | 02:02 PM
SERPENT99's Avatar
Purley for looks man. My jeep has bigger tires in the rearand it looks cool. I made up for the difference in size by running different gear ratios in the axles. Wouldn't a 265/60 16 be a little wider and taller?
Old Feb 29, 2004 | 05:45 PM
aklim's Avatar
OK. Yes it would but like I said the gains would be negligible as far as perfromance went and that was what I thought you were trying to get.
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
