Is my hypertech chip the problem??
Old Jul 30, 2003 | 12:44 AM
Shane87Irocz's Avatar
Angry Is my hypertech chip the problem??
I am having a problem with the rpm's surging/fluctuating with my 87 camaro iroc 350. We went to a local shop to get this thing scanned and we first went on a ride with the mechanic to get his opinion. When going around 55 or so the torque convertor seems to be locking up when I hit the brakes. This makes the rpm's jump up around 350 rpms higher. When the car was scanned it showed that it was running really lean at idle and rpm's surging. They seem to think the hypertech chip is making these problems. They said to get the stock chip and try that one out. The dealer said the stock chip was discontinued so does anyone know where i can get a chip at?? any other suggestions as to why the car may be running bad?
Old Jul 30, 2003 | 11:01 AM
rudy's Avatar
If the problem is primarily an idle condition that appears lean, a O2 on its way out can cause this. As they fail, they loose voltage, and the PCM applies more fuel as it thinks the engine is going lean. When parked, and at hot idle, do the RPM's wander up and down?
Old Jul 30, 2003 | 02:25 PM
SubbaCulcha's Avatar
If surging at idle could be IAC or perhasp even vacuum leak. Check connections to EGR.
Old Jul 30, 2003 | 05:23 PM
IROC-T's Avatar
Chip............
...I wouldn't think it would be the chip (maybe),I would clean or replace the IAC,the O2, and possibly the EGR and passage ways,also check the fuel pressure regulator. These are the things to check first. If it turns out that you do need a new chip and you want a stock chip try a wrecking yard.
Good Luck T.
Old Jul 31, 2003 | 12:03 AM
The EGR works IAC has been checked, o2 is brand new AC delco, VAC lines are all good. From what the mechanics said, the hypertech is locking/unlocking and causing fluctuating at idle.
Old Jul 31, 2003 | 01:19 PM
IROC-T's Avatar
Might call Hypertech and ask them if they have had this complaint before and what could be done to rectify the problem. I'm sure they would giveyou some sort of an answer,may not be what you want to hear,but it couldn't hurt to try,right.
T.
Fatdog2
Mar 31, 2015 06:50 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
brandboZ28
Jan 31, 2003 06:19 PM
slothgrant
Aug 22, 2002 03:01 PM
