My car revs itself !?!
Old Mar 27, 2003 | 01:08 PM
firebirdjosh's Avatar
I remember someone else had this problem before and posted here and now I have that too. I have a 1989 V6 firebird and i was sitting still and the engine revs from 500 -1500 rpm randomly. What do I do to fix it?
I also have a problem with car starting. If it sits for a while, my voltage drops from 14 to about 11 1/4 volts (I measures with a digital multi meter). Sometimes the car takes a few times to start in the morning and after work. I am thinking it is my old battery. What could it be?
Old Mar 27, 2003 | 01:26 PM
Black6SpdTA's Avatar
About the car reving by itself, you probably blew a head gasket. check for any leaks. later
Old Mar 27, 2003 | 08:56 PM
84Z28_5.7ltr_V8's Avatar
does it stop after it warms up a little? the revving i mean.
Old Mar 27, 2003 | 09:44 PM
87IROC-Zowner's Avatar
When an engine starts "hunting" for its desired idle RPM, the IAC (Idle Air Control) valve (motor or soleniod are other terms) is more than likely the culprit.
A new IAC valve from local parts store is usually around $25-45. Fairly simple to install as well. Most of the time a little paper comes with the IAC valve which explains how to properly set it just before installation.
Another thing you might want to check is your vacuum lines/hoses which run throughout your engine compartment and into your dash (heater and a/c controls). A vacuum leak can also cause idle problems.
Old Mar 28, 2003 | 05:22 AM
87 LT1 T/A's Avatar
Better tell it to stop it, or it'll go blind Sounds like a vaccum leak..........
Old Mar 28, 2003 | 11:31 AM
LandryP's Avatar
My Camaro used to do the same thing. I found that most of the vacume lines had dry rotted and were leaking mainly the big one to the brake booster. Cheap fix
PCLZ28
Dec 24, 2015 05:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
USAirman93
Nov 24, 2014 03:37 PM
