My 91 Bird Wont Start How Can I Bypass The Pass Key?
Old Mar 15, 2003 | 11:21 PM
CASPER97TA's Avatar
I replaced the starter cable and it wont start with a jump how do i bypass the pass key? Any other suggestions on what it might be? thanks guys
doug
Old Mar 15, 2003 | 11:44 PM
90rocz's Avatar
Does it turn over fine?
What do you hear when you try to start it, any clicking?
Are all of the battery connections tight?
Headlights bright?
Give me more info and I try to help...
Old Mar 15, 2003 | 11:49 PM
CASPER97TA's Avatar
No turn over, all lights like you turn teh acc. on but nothing. wont jump. starter is brand new and so is battery. connections are tight snd clean
Old Mar 16, 2003 | 01:13 AM
Matt87GTA's Avatar
Just disable the VATS flag in the PROM........ duh....
Old Mar 16, 2003 | 07:39 AM
90rocz's Avatar
There's a pair of really fine wires under the steering column that lead to a connector at the base of the steering column usually labeled "VATS".
Read the resistence across the ignition key and buy a resistor of the same value and jump it across the connector on the side that goes to the ECM. This will bypass it in the event you aren't getting a good connection in the steering column.
But to eliminate it completely you will need custom programming.
armedtrigger
Feb 24, 2015 08:30 PM
Lakebratt
Feb 5, 2015 07:55 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
