My 91 Bird Wont Start How Can I Bypass The Pass Key?
I replaced the starter cable and it wont start with a jump how do i bypass the pass key? Any other suggestions on what it might be? thanks guys
doug
doug
There's a pair of really fine wires under the steering column that lead to a connector at the base of the steering column usually labeled "VATS".
Read the resistence across the ignition key and buy a resistor of the same value and jump it across the connector on the side that goes to the ECM. This will bypass it in the event you aren't getting a good connection in the steering column.
But to eliminate it completely you will need custom programming.
armedtrigger
Feb 24, 2015 08:30 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
