motor mount question?
Old Jul 30, 2007 | 12:03 AM
82lt1ta's Avatar
will a pontiac and chevy 350 have the same motor mounts????
anyone know?
Old Jul 30, 2007 | 12:34 AM
quickchicken's Avatar
yes they do, if you are talking about your third gen refering to your list in your sig.
if your doing this motor in its gonna be a bit tight in the eng bay but as for reaching the nuts in hte K member behind the spring, use a knuckle and a loooooooooong extension. also tape the knuckle so it stays put and dosent woble and dump the nut as ya reach in.
Old Jul 30, 2007 | 12:45 AM
82lt1ta's Avatar
ok cool thanks
Old Jul 30, 2007 | 12:47 AM
82lt1ta's Avatar
i did a motor swap once, but my buddy spun a bearing so i gotta do it again, so i am gonna take the pontiac 350 that i have laying around and put it in the lil ole 3rd gen
Old Jul 30, 2007 | 12:53 AM
now that changes the game a lil. i dunno if that Olds 350 will bolt right in. i was under the assumption this was a 350 from a third gen firebird. go to WWW.THEFORMULASOURCE.COM and ask around. there are some classic bird guys there that can SURELY andswer that ques.
Old Jul 30, 2007 | 04:42 PM
Dave89IROC's Avatar
mounts are different, not even sure if the motor will physically fit in the bay
Old Jul 30, 2007 | 09:03 PM
Stephen 87 IROC's Avatar
Bellhousing is different. The B-O-P-Caddy bellhousing is different compared to the Chev SBC/BBC engines. You'll need to change the tranny or find one with a dual bolt pattern.
HectorM52
Jul 30, 2017 11:46 AM
alliance12364
Mar 6, 2015 04:39 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
