miniram & thermostat housing?
anyone have or had problems with this area? the way mine is designed i have to put the thermostat in the housing and then try to get it onto the intake which always seems to be a hassle....terrible design. just curious if anyone else dealt with this and found a better solution.
Re: miniram & thermostat housing?
Sorry.
I know what you mean about the fast burns. My friend Tony who does my tuning has a set on his 89 Vette and the miniram is pretty much his only option at the moment.
So, back to my question, is it the TB that gets in the way of the thermostat housing or the manifold itself?
I know what you mean about the fast burns. My friend Tony who does my tuning has a set on his 89 Vette and the miniram is pretty much his only option at the moment.So, back to my question, is it the TB that gets in the way of the thermostat housing or the manifold itself?
more or less the problem of how it's designed. rather then letting the thermostat rest on the manifold and just put the housing over it with a simple bolt-down procedure it's the other way around which makes it difficult. you have to put the thermostat in the housind and manage to line everything up on the manifold perfect. doesn't sound bad but it's very hard to tell how you have it once it's together......just a poor design.
??? huh???
I was messing around with my thermostat on the miniram just today, and I'm not having any troubles at all. I simply remove the throttle body. In addition, I'm using an early GM waterneck, though I have a TPI waterneck as a backup. I'm not sure how the water will route out of there such that the hose doesn't get tangled in the serpentine belt, but I'm getting there.
Dan's miniram project
The other view
Those pictures are a few days old. It looks a little more complete now.
The other view
I am having problems with my thermostat housing neck hitting the bottom of my throttle body-is this what you are talking about? anyone else out there having this problem? any info is appreciated-
