mini starter
Old Apr 8, 2004 | 04:52 PM
  #16
aklim's Avatar
Well, never having had to do that, I wonder why it became necessary unless the fittment is that bad.
Old Apr 8, 2004 | 05:11 PM
  #17
zulater91's Avatar
i think i might try another starter to see if it fits any different.
Old Apr 8, 2004 | 05:46 PM
  #18
TheGreatJ's Avatar
Ever notice how the starter drive gear on a factory GM starter is almost 3 times as thick as the ring gear? It's because the production tolerances on starter bolt holes are THAT bad. This is the same reason GM starters have to be shimmed away from the block. They made the drive gear extra thick to compensate for not knowing how far out it would need to extend, and you shim it to compensate for not knowing how far from centerline the boltholes are. You may just have a block that's on the extreme edge of factory tolerance. Try a different starter and if it has the same problem you'll just have to space it back farther.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
Jul 17, 2015 02:47 PM
