LT1 intake manifold on a tpi?!?!?!
Old Aug 17, 2005 | 02:24 AM
Runin2Nite's Avatar
how hard is it to take a lt1 intake manifold and make it bolt up to my tpi. is this somthing that i can convert in my garage? and do i need the fuel rail and upper and lower manifold???
i just found a doner motor and i gotta act fast. any help is appricated!!!
Old Aug 17, 2005 | 09:30 AM
diehardgm's Avatar
Re: LT1 intake manifold on a tpi?!?!?!
It is not really simple. Bolting the manifold up is no problem, you will not need any part of the original TPI manifold. You will have to drill the LT1 intake for a distributor since it uses an optispark and a custom spacer will have to be made to make the correct height for the distributor. Also, the LT1 has reverse coolant flow and therefore does not have a place on the intake to bolt your thermostat housing neck. This will require some engineering. Do some research before attempting this project. I am sure there are some on this board that can tell you exactly how to do it.
Old Aug 17, 2005 | 04:55 PM
mako350Z28's Avatar
Or you can send this guy an email.
Old Aug 17, 2005 | 05:00 PM
Zepher's Avatar
You can do it in your garage, as John at the link above did a few years back when he was starting out.
It doesn't seem that hard if you are good with measuring and cutting/drilling/welding.
I am not good at any of those tasks. John is a good guy too, he helped me with my TPI swap 4 years ago, redid the harness from MAF to SD, helped diagnose problems over the phone, etc....
markaubuchon
Jan 14, 2015 01:48 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
