LT1 install, what clamshells?
Old Jul 24, 2004 | 04:38 PM
Mike454SS's Avatar
In order to install an LT1 into an 86 IROC, what clamshells need to be used. The engine has F-Body accessory brackets and an AC delete pulley, so fitting the compressor isn't an issue.
The IROC has the original rubber mounts on the K-Member still, but the clamshells that bolt to the engine are not there. I have new Energy Suspension engine mounts that I plan to install, but I need to know which clamshells I need to get to bolt into the IROC.
The LT1 I'm using is coming out of a caprice, so it has normal GM clamshells on both sides, but isn't the passenger side too far back? Is it offset to move it back, or are there 2 mounting pads on the side of the LT1 block?
Old Jul 24, 2004 | 05:28 PM
slimdawson's Avatar
Re: LT1 install, what clamshells?
I reused my stock 305 mounts. I had to beat on one to clear the compressor but you won't have that problem.
Old Jul 25, 2004 | 01:03 AM
Dave89IROC's Avatar
yes, there are 4 holes, only three are used for either mount, just use the pass side clamshell for the third gen
Old Jul 25, 2004 | 04:21 AM
Mike454SS's Avatar
I have another parts car (but I only for another couple days) so I'll steal the complete mounts from it before I kiss it goodbye just to make sure I have everything I need when swap time comes. Thanks for the help.
Old Jul 25, 2004 | 02:44 PM
Zepher's Avatar
The block has 2 locations for the engine mount on the pass side, use the one that is parallel to the drivers side.
HectorM52
Jun 23, 2016 08:42 PM
Jason Short
Jan 19, 2015 06:34 PM
Fedesna
Nov 23, 2014 11:06 AM
