LT1 Heads came today, updated the site!
Old Feb 12, 2004 | 06:10 PM
Black6SpdTA's Avatar
Talking LT1 Heads came today, updated the site!
The heads are here! I'm going to buy some T6061 Aluminum this week and possibly start tackling this project. Dang, these things are light! I wouldn't be afraid to say they weigh half as much as the old iron castings! I'd urge some of you fellow 3rd genners to attempt this. I can't say how difficult it will be, but it sure will be fun once it's all over and I'm beating LS1's!!!
Well, check out the site:
http://www.cardomain.com/memberpage/400090/9
Old Feb 12, 2004 | 07:25 PM
Blown350ZZ4's Avatar
Looks good man. I'm sure by this point you know every nut and bolt in your car. I am almost there myself. Good luck with it.
Nick
Old Feb 12, 2004 | 09:49 PM
97WS6SCharged's Avatar
Yeah, if you check the shipping weight, you'll probably find they're about 21-23 lbs.
Old Feb 13, 2004 | 10:49 PM
Jids's Avatar
Lt1 heads on a TPI car???
someone help me out....
Old Feb 14, 2004 | 08:04 AM
Bolt patterns are the same from heads-block. Only problems:
Intake
I'm using a converted LT1 Intake from www.LT1Intake.com so that's that.
Reverse Cooling
There are the standard 6 cooling ports in the middle. LT1 Heads, which are reverse cooled, also have an extra four (tw on each side) on the ends of the cylinder head. These extra four simply need to be blocked up. I plan on buying some T6061 aluminum (3/16" Flatstock maybe) and cutting it out to shape. I'll tap the piece into the cooling ports ~1/8" deep, then weld them into place. Take the heads to a machine shop, have them milled.
Walah.
Old Feb 14, 2004 | 08:47 PM
Jids's Avatar
Intake
Reverse Cooling
Walah.
thanx!! learn something new everyday!!
Old Feb 14, 2004 | 08:58 PM
Ok guys, new batch of parts arriving:
-LT1 Rods (PM Stlye- Up to 450HP)
-LT1 Pistons (Attatched to rods, had to pay mad extra shipping )
-LT1 Intake
-LT1 Fuel Rails
Shoud all be getting here by the end of next week
Boy, it seems like I'm building an LT1 here doesn't it? Well.....I am, Cammed and Built SBC Style
Old Feb 14, 2004 | 10:39 PM
TheGreatJ's Avatar
Doing the LT1 swap without all the messy fabrication and Optispurt, eh? Sounds like the way to go.....
Old Feb 14, 2004 | 10:48 PM
Exactly. Plus....cheaper
Old Feb 15, 2004 | 12:23 AM
I've got a stock LT1 cam you can have.
Old Feb 15, 2004 | 12:29 AM
94LT1Maro's Avatar
Hmmmmm well if your giving an LT1 away i'm interested lol
Old Feb 15, 2004 | 12:59 AM
doug791's Avatar
70 bucks eh.....and comes to around 200 total? Get some porting done on that and it seriously wins out over purchasing a similarly designed mini ram for around 1000 dollars from a company that i hear a lot of questionable things about.....might have to go that route my self
Old Feb 15, 2004 | 02:13 AM
Shipping plus gas money and you can have it.
Old Feb 15, 2004 | 11:12 AM
Zepher's Avatar
You can do the same with an LT1 engine with an LT1 intake with a dist. hole added.
Old Feb 15, 2004 | 05:44 PM
Haha, I would, but then there'd be no room for the XE 230/236
I've got an L98 cam, trade you straight up?
