LT header install. Help!
Old Apr 8, 2006 | 01:36 PM
  #16
conlinj's Avatar
Re: LT header install. Help!
Originally Posted by Rottluver
That's kinda what I thought........but far be it from me to say someone has bad info.
Oh yeah, what is a wonder bar?
it's basically a bar with 2 tabs that mount to the sway bar chassis mounts to reinforce the steering box. It's a weak area in thirdgens and prone to cracking.
-Jim
Old Apr 8, 2006 | 02:20 PM
  #17
Rottluver's Avatar
-Jim
Gotcha, thanks for the info.
Old Apr 8, 2006 | 02:25 PM
  #18
conlinj's Avatar
Anytime! now back to the original post...
What shape are the motor mounts your using in?
Old Apr 8, 2006 | 08:03 PM
  #19
Jim D's Avatar
I put new motor mounts in...That was an education in itself, getting to the two top bolts on them.
As far as the difference in the A-arms and frame, I had never heard of that either. Just quoting Hedman on that, and that's why I asked here. I figured someone here would either confirm it as a little known fact or say no way. Thanks for the info guys, I will be ordering HED-66469.
I will follow up when I get them in, but it may be a while. Looks like I may move from NY to NC in a few weeks...
Old Apr 10, 2006 | 09:26 AM
  #20
Rage's Avatar
I installed new mounts from O'rielly's, but I finally got the header to fit. I got the trusty cutting torch out and went to work. I cut the knuckle off the A-arm all the way back to the bolt. and relocated brake lines and dented the header where it made contact with the K-member. Even after cutting the A-arm I still had to dent the header. The dents are minimal though, so I dont think it will hurt anything. But the fit, and the install isnt really that bad. It just takes time. Thanks for the help.
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
CARiD
Jul 7, 2015 08:19 AM
