LT-1 crank in L-98 TPI 350???
Old Apr 3, 2003 | 12:05 PM
GreenMonster138's Avatar
Will a Lt1 crank work with a tpi motor? I know that the lt1 cranks are stronger, but not sure if they will work with the L-98 350? If not what are the reasons for them not working?
Old Apr 3, 2003 | 12:36 PM
rickyzZ28's Avatar
If your block is a 1 piece rear main seal it should work. If not you have to convert the crank to a 2 piece rear main, but I do not know what is involved with that.
Old Apr 3, 2003 | 02:57 PM
Black6SpdTA's Avatar
yea itd work fine, like rickyZ28 said if its pre 86 get a conversion kit, they arent that expensive from summit or jegs or somethin.
Old Apr 3, 2003 | 11:06 PM
Geoffmj's Avatar
I just read this on a website:
CRANKS
350 - The crank for the LT1 looks just like the one in the late 350 and has the same casting number 14088526, but it’s balanced for the lightweight pistons that were installed in the LT1. Be sure to keep these cranks separate so they don’t end up in a regular 350, and don’t ever use a regular 350 crank in a LT1. In fact, if you are short of LT1 cranks and don’t have a balancing machine in your shop, you would be better off using a crank from a 305 instead of a 350 because it’s actually closer to the balance specs for the LT1 crank.
I got it from
http://www.automotiverebuilder.com/ar/ar99928.htm
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
sskevinm
Dec 18, 2014 11:16 AM
4586
Dec 6, 2014 05:20 PM
Chris Ja
Aug 1, 2002 07:30 PM
