Ls1 T56 In 89 Iroc!!
Old May 12, 2005 | 03:38 PM
  #16
masiroc566's Avatar
Re: Ls1 T56 In 89 Iroc!!
Originally Posted by iansane
I'm using the Weir setup as well. The LS1 t56 doesn't have a clutch fork, it uses a hydraulic throwout bearing (combines the slave cylinder and Throwout bearing in one unit).
Works great once I got the air out of the lines. Didn't last as long as I would've liked but it works awesome. I've had it in the car for the last year and daily driven about 25-30K and I just got the throwout bearing back from it's first rebuild.
i didnt use the throwout unit that came with the kit. I went to GM and used the one they sell for the 98-02 camaros...cuz of the line feed connector from the clutch slave cylinder didnt fit the one weir sold me.
Old May 12, 2005 | 03:41 PM
  #17
masiroc566's Avatar
Originally Posted by 92rslt1
I dont get it.. Why do all this when a lt1 t56 practicly is a bolt on mod?? There is next to no difference your gonna notice other than the ls1 is a pain and more expensive to put in. So why go though hell again??
Well cause I didnt realize there was a difference in the T56. I bought the tranny prior to finding out that there was a difference....being new at the whole thing....I just didnt know better....but now i do.....$$$ down the road....but yes your right the LT1 would have beed the route to go....
Old May 12, 2005 | 03:55 PM
  #18
iansane's Avatar
The what?
The Weir unit doesn't have a slave cylinder, what are you talking about? The Throwout bearing IS the slave cylinder. They combined them into a single unit.
Old May 12, 2005 | 07:08 PM
  #19
masiroc566's Avatar
The what?
what I meant is the part that pushes in the fork on the other type of hydraulic systems!
Old May 12, 2005 | 08:06 PM
  #20
85_305's Avatar
Re: Yes It Can Be Done LS1 T56 In 89 Iroc!!
Well I had to do research in finding a bell housing that would fit. I made several calls and finally after about a mouth I found the guy who makes them...his website is... www.weirhotrodproducts.com he will be able to help you with any application you desire...
ahhh, that musta sucked tryhing to find a damned bellhousing
Old May 12, 2005 | 11:34 PM
  #21
iansane's Avatar
Yeah... That's the slave cylinder. There isn't one in the Weir setup so how would the connector not work? I'm confused what you were trying to do.
Old May 13, 2005 | 12:32 AM
  #22
masiroc566's Avatar
You must be confused....Im not!! These two pictures will clarify what I did to my car and after you see them then you will understand that the kit I bought from weir would not work!! http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting http://www.paceparts.com/index.asp?P...D&ProdID=24693
Old May 13, 2005 | 12:54 AM
  #23
iansane's Avatar
OOOh. I see now. That thing pictured is your MASTER cylinder. You needed a 1" bore MC. The stocker won't work. But it's nice to know that the LS1 style throwout bearing will work. I had contemplated that route.
Old May 14, 2005 | 02:24 AM
  #24
masiroc566's Avatar
Just curious...what shifter did you use on your T56. Mine came with the SLP short shifter and the length of the stick is too short. When I shift the stick hits the console....
Old May 14, 2005 | 02:35 AM
  #25
iansane's Avatar
I've got the stock shifter and a shortened shaft and a carbon fiber boot. As soon as I get around to it I'll be ordering a pro5.0. I've heard those to be the best. I've also got a '00 Trans Am console in the car which sits a lot lower than the standard 3rdgen one. (basically nothing hits. )
Old May 14, 2005 | 03:50 AM
  #26
masiroc566's Avatar
You have any pictures of that?
Old May 14, 2005 | 04:48 AM
  #27
iansane's Avatar
From before I tightened the console down... Kinda blurry. The red thing behind the shifter is the engine start button.
Old May 14, 2005 | 01:13 PM
  #28
masiroc566's Avatar
Did you have to modify the radio bezel? You have an engine start button....hmmmm...I had problems with mine also that it didnt want to start the correct way...so I had to put a starter buttom in myself...Was it too difficult to bolt down the console or was it an easy thing? Thx
Old May 14, 2005 | 04:05 PM
  #29
iansane's Avatar
My bezel is completely stock, but I have a bird so it's a two piece thing. The 'maro ones car just be cut to fit for an even tighter seam. It was easy to bolt down. Originally I just had some self tappers in there but I tacked a few nuts on the bottom and just use bolts.
Old May 14, 2005 | 06:20 PM
  #30
masiroc566's Avatar
Hey Thx for the info!!! By the way...The clutch is easy to push in...Not a hard clutch at all. My Ford F150 has a harder clutch than this Camaro. Very Impressive!!!
