Loose steering column
Old Jun 20, 2004 | 08:43 PM
firebirdjosh's Avatar
I got in my car today and my steering column is very loose all of a sudden. I can rotate the column and wheel about an inch in every direction. I remember seeing a website around but can't find it. Has anyone had this problem? How hard is it to fix?
Old Jun 20, 2004 | 09:10 PM
bluirocz85's Avatar
Go to http://home.t-online.de/home/O_Scholz/steering.html. This a very good illustration about how to tighten up a GM steering column. Better use thread lock on the tilt bolts or they'll loosen back up soon.
Old Jun 20, 2004 | 09:20 PM
Thank you soooo much!!! Atleast I can install a new turn signal switch and steering wheel while im at it.
Old Jun 20, 2004 | 09:29 PM
bluirocz85's Avatar
You might have to copy and paste this link. I tried clicking the link and it didn't work. I have this saved in my favorites and it works fine by copying & pasting.
Old Jun 20, 2004 | 10:22 PM
The period at the end of the hyperlink is what screwed it up. I saw it and it works great! Thanks.
Old Jun 22, 2004 | 02:54 AM
FruityOne's Avatar
I've done this job. Just bey VERY carful with the bearings in the column! Don't lose one or you will be cursing up a storm!
My first time through it took me about 1 hour of actual work, not including the research I did.
Old Jun 22, 2004 | 09:23 AM
Oh good, I was expecting 2 just to get it off. I'm excited now, just need a steering wheel and turn signal.
Old Jul 15, 2004 | 02:03 PM
FruityOne's Avatar
So, how did the job turn out?
Old Jul 15, 2004 | 03:38 PM
Ucantcme57's Avatar
I bought my camaro like this the whole column would move toward the top and the floor board like two inches, and when I would drive sometimes the car would shut off(not good!!!) I tore it down and there are some torx bolts that go from column to dash, those were loose, Wish I could figure out how to get that pesky high beam rod back in right????
Old Jul 15, 2004 | 03:40 PM
Ucantcme57's Avatar
Can't get link to work.. was hoping to see the high beam rod put back in.. Someone help!!!
Old Jul 18, 2004 | 06:57 PM
PearlWhiteZ28's Avatar
Re: Loose steering column
The link works - just remove the last period after "html".
A have also used these instructions - they're great!
I also have a detached steering column in my laundry room if you can't figure it out from the pictures. might take me a bit to figure out how to post a picture thought.
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
