Keyless Entry....
Keyless Entry....
Im considering adding keyless entry to my Camaro. It's an 87, it does have power locks, but does not currently have keyless entry. I wanted to take the keyless entry out of a newer Camaro and plug it in to mine. Will this work? Is the harness compatible or will I have to splice it all?
Re: Keyless Entry....
You'll have to get the box, key fob, and the connector that plugs into the box. Then run power and ground to it and splice into your power lock wiring. So you'll need wiring diagrams for the donor car and your car also.
gelbza
May 29, 2015 05:50 PM
