Key Stuck in Ignition
Today I was backing out of my garage to work on my car, all was well, then I to take my key out and it was stuck. Then I thought the stearing was locked, took it out for a spin and it was fine, stoped the car but it was still stuck. Tried playing with it but it won't come out. It will turn off and on but won't turn to the LOCK position and won't come out.
Any help will do just fine, and if you have any questions just ask.
Re: Key Stuck in Ignition
this happened to my buddys 3rd gen once, i remember. from what i remember, it was one of those things where we tried for like an hour to get it out, and nothing, then stopped, then got pissed and went back at it and it came out eventually on its own, then he got the ignition cyl. changed
he said the key does not turn to lock,
the key is meant to be held to the steering column as long as the key is not in the lock position,
i believe once u get the key to the lock position it will come right out
what may cause the key no to go to lock may be as simple as the safety neutral switch or the brakelight switch or the ignition switch
i'm sorry i can't tell u exactly what because i'm not exactly sure
Make sure that the button on your shifter **** is released all the way. My bonneville does this to me sometimes. With the button stuck (from a Mountain Dew Spillage) it would not turn all the way back sometimes.
well, I have a B&M shifter, so It's auto but the lever is not stuck.
I tried again today and it still won't budge... don't want to put to much muscle into it or it might break, then I'm ****ed.
You said that you thought that the steering was locked so I assume that you maybe have tried turning the wheel some while turning or pulling the key?
As someone mentioned,I also think that you'll need a new lock cylinder.
This happend to my Grand Am like a week or so ago....i just gave it a little hit with the palm of my hand a few times.......and it still would not turn.then i turned it realy hard the some thing broke and gave loose.it has stuck like this once befor.but it was never this hard to turn.but a week went by and it has not happend again
pimpinphil
May 30, 2015 04:20 PM
