Key Stuck in Ignition
Old Jul 17, 2005 | 08:50 PM
83CamShikwon's Avatar
Today I was backing out of my garage to work on my car, all was well, then I to take my key out and it was stuck. Then I thought the stearing was locked, took it out for a spin and it was fine, stoped the car but it was still stuck. Tried playing with it but it won't come out. It will turn off and on but won't turn to the LOCK position and won't come out.
Any help will do just fine, and if you have any questions just ask.
Old Jul 17, 2005 | 09:07 PM
Hedzilla's Avatar
Re: Key Stuck in Ignition
this happened to my buddys 3rd gen once, i remember. from what i remember, it was one of those things where we tried for like an hour to get it out, and nothing, then stopped, then got pissed and went back at it and it came out eventually on its own, then he got the ignition cyl. changed
Old Jul 18, 2005 | 12:25 AM
billyhoss's Avatar
if u have an auto make sure its all the way in park , had it happen to me before and it was not all the way in park
Old Jul 18, 2005 | 10:14 AM
respectirocz's Avatar
he said the key does not turn to lock,
the key is meant to be held to the steering column as long as the key is not in the lock position,
i believe once u get the key to the lock position it will come right out
what may cause the key no to go to lock may be as simple as the safety neutral switch or the brakelight switch or the ignition switch
i'm sorry i can't tell u exactly what because i'm not exactly sure
Old Jul 18, 2005 | 10:55 AM
zcamaro28's Avatar
I had that same problem in my '84 i just had to put a little muscle in it and then it came out.
Old Jul 18, 2005 | 02:46 PM
RedIrocZ-28's Avatar
Make sure that the button on your shifter **** is released all the way. My bonneville does this to me sometimes. With the button stuck (from a Mountain Dew Spillage) it would not turn all the way back sometimes.
Old Jul 18, 2005 | 10:57 PM
well, I have a B&M shifter, so It's auto but the lever is not stuck.
I tried again today and it still won't budge... don't want to put to much muscle into it or it might break, then I'm ****ed.
Old Jul 19, 2005 | 08:31 AM
91Zman's Avatar
You said that you thought that the steering was locked so I assume that you maybe have tried turning the wheel some while turning or pulling the key?
As someone mentioned,I also think that you'll need a new lock cylinder.
Old Jul 19, 2005 | 04:31 PM
defbear's Avatar
When this happened to mine I would put it into Neutral and Park a bunch of times and eventually it would free up the key.
Old Jul 19, 2005 | 10:16 PM
I fixed it today, took a screwdriver and poped it out. It seems to work fine now, but I'm going to go buy a new cylinder for it.
Thanks for all your replies!
Old Jul 20, 2005 | 04:12 AM
MotorCityNova572's Avatar
This happend to my Grand Am like a week or so ago....i just gave it a little hit with the palm of my hand a few times.......and it still would not turn.then i turned it realy hard the some thing broke and gave loose.it has stuck like this once befor.but it was never this hard to turn.but a week went by and it has not happend again
KYWes
Jun 14, 2022 06:52 AM
surreybrad
Jul 5, 2015 10:36 PM
pimpinphil
May 30, 2015 04:20 PM
Dzmaro
Jan 25, 2015 10:39 AM
WipeOutXXL
Aug 5, 2002 09:27 AM
