keep eating alternators ????
Old Apr 5, 2003 | 09:19 AM
1SLOSBC's Avatar
88 iroc serpentine style..... i eat them right and left, no big stereo or anything.
has anyone had this problem and know how to fix it. ive re wired everything and it still kills them.
Old Apr 5, 2003 | 10:39 AM
Dave89IROC's Avatar
what type of alternator do you have, the older SI or the newer CS, you should have a CS, I know if the L terminal at the alt has less than 35 ohms in it it will kill the voltage regulator, so you may want to check that
you can watch this thread also, we're trying to get his alt charging, has some good tests
http://www.thirdgen.org/techbb2/show...hreadid=170850
Old Apr 5, 2003 | 11:07 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
I went thru five cheap-*** no name rebuilt alternators in 2 years before I finally paid the extra money (at a discount GM dealer) for a genuine Delco brand new alternator. Its been running great for more than two years now. (knock on wood)
Old Apr 5, 2003 | 03:17 PM
FerrMaro's Avatar
really loud
my alternator is fine, but its really loud. like loud...is anybody elses loud??? it kinda sounds like...slightly metallic...well it sounds like an alternator just really loud.is this normal for third gens??thanx
Old Apr 5, 2003 | 04:26 PM
ZZ430RS's Avatar
Take your belt off and see if the pulley has any play in it, if it does the bearings are bad in it, if it's making a sound like a little supercharger, gets hot real fast and your volts are a little low then 1 or more diodes have gone out in it. Best fix is to take it to a good alternator & starter repair place and have them go through it, or do it yourself, a guy here will replace the diodes and bearings for $40.00, cheap rebuilt ones are junk usually, even the lifetime ones.
Old Apr 5, 2003 | 06:04 PM
1SLOSBC's Avatar
that loud nosie can be a idler pulley as well, but usually the rear bearing in the alternator.
cheap, lifetime and name brands are all junk, alts suck
going to get another one now.
gotta have it running good soon. dyno is comming up, im shooting for 450rwt out of this all motor small block.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Pwilson59
Sep 3, 2015 08:47 PM
